Shock question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TexasBlazerBoy, Feb 12, 2007.
  1. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Installing 4 inch lift
    I got four new shocks
    Two are long
    Two are short
    Which two go in the front, long or short?:doah:
  2. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    short ones in for the front, long ones for the rear
  3. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You may want to look at an inboard shock setup (like this: /\ rather than this:\/) it really helps out articulation...and the stock rear shock mounts on our trucks suck and extremely limit flex.
    -Harrison
  5. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Like the one DIY4x has on his web page
  6. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Did your truck come with dual shocks from the factory? If so, install the shocks on the lower mounts. I can get pics of mine if you need it.
  7. dmoney
    dmoney 1/2 ton status
    Jan 21, 2007
    119
    Silverhill, Al.
    I have a 90 burban that I put a 6inch rough country lift on and I have quad shocks up front. They sent me two shorts and four long, so I thought the long went in the front... so do I need to switch the rear ones to the front? I did notice that the rear front shocks have a shorter mount so do I change them to the rear ? Then if I go with the ord flip kit for the rear do I need new(longer) shocks?
  8. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
  9. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    No my truck did not come with dual shocks, only single.
    I put the short shocks up front.
  10. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    So does this mean you are closer to being ready for Shiloh? ;)
  11. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    I freakin hope so.
    I got my 12 bolt dropped, springs out and one hangar ripped off last night. Now I get to do the other side:eek1:
    It is going pretty well so far. I just hope repairing the brake lines that I broke up front won't be to horrible.:doah:
