Shock Question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 724fishin, May 13, 2002.
  1. 724fishin
    724fishin Registered Member
    Oct 12, 2001
    20
    Antioch, CA
    I am putting a 4in BDS lift on my 72 Jimmy and am planning on using Rancho 9000 series shocks. I currently am using 9000 series shocks. The Rancho application guide says with a 4in lift I should be using a 9001 in the front. At compression it is 13.25 in and extended 20.75 in for a travel of 7.5 in. My current rear shocks are a 9008 with a compression of 13.625 in and extended at 27.70 in for a travel of 14.125 in according to the application guide. If the compression length of the recommended 9001's is almost identical to the compression lenght of my current rear shocks, is there any reason to not use my current rear shocks in the front and get 7 more inches of extension on the shock?
  2. 724fishin
    Oct 12, 2001
    20
    Antioch, CA
    Nevermind, I just looked at the numbers again for the 9008 shock and they don't make sense, it would be hard to stretch a 13.6 in shock to 27.7 in without it falling apart.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That # has been wrong on their website for a LONG time...maybe if enough people email them about it they will finally fix it?
