Shock Therapy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Effyoo, Oct 17, 2001.
  1. Effyoo
    Effyoo Registered Member
    Sep 26, 2001
    27
    Akron,OH
    While underneath my new 88 Jimmy, I noticed that there is a bracket attached to the frame where the top of a second shock would be mounted. I know that some of these trucks got dual shocks in the front. I didn't see a lower mount. Did all of the K5's in this year range come with the top bracket for a 2nd shock, but no lower one if the truck wasn't so equipped? What determines which trucks got single and dual shocks?
    "There are 3 kinds of people in this world...Those who can count, and those who can't"
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I believe taht the bottom of the second shock mounts on the same bolt as the first shock...just a longer bolt or whatever is used I dont think its what years i think it was just a factory option...I dont believe mine has the second bracket inplace but i have heard its nothign to get the equipment and mount it up......one other thing I have also heard is that it stiffens the front end drastically and some people therefore prefer single over double
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer<P ID="edit"><FONT class="small">Edited by BowtieBlazer on 10/16/01 11:11 PM.</FONT></P>
  3. I have a 89 K5 that had factory quad shocks up front. When I put my lift in, I went with 2 shocks instead of the 4 up front. I think having 4 shocks up front will make it too stiff unless you use an extremely light duty shock for the other 2 up front. The bottom bolt is longer and has a spacer to keep the shock bottoms spaced apart.
    Later,
    Doug
    4 wheelin's not a job, it's an adventure!
