shock ?
Discussion in 'The Garage' started by 88burb, Dec 12, 2004.
  1. 88burb
    88burb Registered Member
    Nov 15, 2004
    33
    i just put a 14bolt ff out of a 78 1 ton 4x4 in my 88 suburban and my shocks hit the axle tube and i cant mount them can i turn my shock upside down just until i can weld new shock mounts on i have skyjacker hydro shock anyone know ??????
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you can run it without shocks if you had to but it will be a little bouncy.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    what kind of shocks are you running. Each shock and each manufacturer recommends different things for thier shocks. If you do a little looking into different shocks you will find out how they recommend them being mounted, or you can call them and ask (my preferred method).
    I personally would prefer to run all of my shocks with the bottle up and the piston down... less weight on the axle side and I think they look better... but thats only when running a boot and obviously opinions will vary.
  4. 88burb
    Nov 15, 2004
    33
    ya i could run it without shocks but its my dd and my work is 30 miles one way i have seen people run shocks upside down but just wanted to know for sure if it was ok to do !!!!!
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have run no rear shocks on my K5 for over 2 years. It is pretty much a DD. I say turn the shocks over for now and call it good. I know you can run Rancho 9000's upside down, but I think they recommend against running RS5000's that way. I am not sure why, but each shock is different.
    Harley
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My drivers side rear shock has been upside down since spring , I haven't noticed any problems yet , although I really should grind the edge of the springplate , it will scratch the shock body when flexin' . Hers an early pic of the originla lift shock on it before I put the gabriels on :k5: :k5:
