Shock ???
Discussion in 'The Garage' started by bamf, Sep 2, 2005.
  1. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    Fayetteville North carolina
    ok so my K5 blazer i just bought has some crappy ass shocks lol who ever owned it before me screwed up the shocks some how. There no bushings left in the shocks so its just the metal loop and a bolt holding up the shocks. anyways i have a few questions.
    1st ? is right now the truck has duel shocks up front but I dont think its right the way its set up.
    each shock has its own bolt on top
    but at the bottom there shareing the same bolt so one shock is in the shock mount and the other is right next to it with a spacer?
    So the ? is should i just use one shock? or should i keep the set up he had?
    also whats the best shock to use ? Right now i only plan on making it my daily driver.
    it does have a 4in lift and 35in tires
    thanks
    Alan
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    the set up you described is stock for the front end... just put new bushings in unless the shocks are worn out
  3. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    okay so stock k5 have duel shocks up front like that?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Quad front shocks were a factory option, and yes, they were mounted just as you describe (although they DID have bushings). ;)
    You can buy a single shock for each side and do away with the extras. Unless you're desert racing the extra shocks just make the ride harsher.
  5. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    mine came with it. but i did notice the outside shocks on mine limited my down travel by an inch or so so i took em off. so i now just have 1 shock on each side.
  6. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    yeah im going to go single shocks on each side.
    unless theres a good reason to put duel
    for a daily driver
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    most people like bilsteins. just run one on each corner
  8. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    also i got all the shocks off the truck execpt one i got the nut off but for some reason the bolt wont slid out of the shock i cant bang the **** out either cause the axle is in the way. so how the hell should i get this bolt out? any ideas
    its the passenger side front shock and the bottom bolt thats giving me this pain
    any ideas?
  9. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    ok i had to cut that damn bolt off now.
    heres another ? how can i tell what shocks will fit my truck someone told me i would have to get cutom shocks cause of the lift it has a 4 in lift
  10. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    After installing Bilstein 7100s on the front of my Cummins ram I wouldn't install factory style quad shocks anymore. The ride control of one good shock is just amazing. If I did it again I'd install the 7100s on the rear also, currently have the 5150s and should have just spent the extra $$ for the rears. The 5150s aren't really that bad but you can notice the difference.
  11. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    is that the only color they come in ? lol blue and yellow?
