Shocks and brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxrcr589, Mar 25, 2004.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    I just got my 6" BDS springs, im picking up a steering arm from a friend and now i just need shocks and brake lines. I got some brand new Fabtech shocks from my friend for free, but they are from his 95 chevy 1500, and they are 2 different sizes, i think 2 were from the front and 2 were from the rear. The rears have like 14" of travel and then the front have about 10 1/2". My question is how much travel is needed for a 6" lift, and is the front and rear the same, i have dual in the front but i only plan on putting single up front. I have a 3inch on there now, can i still use those shocks until i get new ones? My second thing is how long to my brake lines have to be? Is it worth getting steel cables or just cheap ones from the local auto parts store?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    lots of questions here...
    on the brake line issue, I run procomp stainless lines and like them a lot. They really arent very expensive at 4WPW.
    on the shock issue, good idea only running a single shock on each side up front... with modern shock tech, duals really arent needed unless you're doing some crazy desert racing washboard stuff or something. Length of the shocks, I dunno, after you put the lift on, just measure... that'd be the best way to know for sure because every rig is a little different. IMO, once you start lifting a rig and stuff its time to custom mount shocks... doesnt have to cost a lot, ford shock towers are cheap and work well. I never took a measurement for my DT8000 shocks... just got the longest ones they made and mounted them at the height of my choice. /forums/images/graemlins/smile.gif
    lastly, do searches, this kinda stuff is covered a lot. /forums/images/graemlins/wink.gif
    j
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Front brake hose:
    These ones are for the left front of a 1994 2wd 1 ton and are around 25" long. $13.99 at Advance Auto. Napa wants $16.69.
    Tru-Torque (Advance Auto): H38873
    Napa: H38873
    Bendix: 78227
    Raybestos: BH38873
    Wagner: F124600
    Rear brake hose:
    Napa #4138068. It is $13.99
    Shocks are a tricky subject. Some people have preference over others. I recommend going to the auto parts store, asking for the shock book, and look through the pages to find one that is the right length for your application. For my truck with a 4" lift, I ended up running some Gabriel shocks that are 27.25" long in the rear and stock rear shocks in the front in the auxilary shock position (of the quad shock setup). You're going to want a shock about 30" long in the back if I remember correctly. Not a whole lot of them out there either.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    G63438 Gabrials, 30" long, 12" travel
    I have them at all four corners. $20 each and lifetime warranty.
  5. mxrcr589
    Apr 17, 2003
    148
    poop
    thanks alot
  6. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    This is for 4" or 6" lift???
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have 6" of lift, the book says that they're for 4". I have ford towers up front and stock style mounts in rear.
