Shocks through Floor board??
Discussion in 'The Garage' started by chevysmithz71, Apr 24, 2007.
  1. chevysmithz71
    chevysmithz71 1/2 ton status
    May 26, 2005
    1,464
    Kingsburg, Ca
    I have some 7100 Bilstein shocks that are way to long for the rear of the Blazer. I was going to use them on another truck but didn't go that way. So after seeing the build in the Petersen issue I saw that they mounted the coils to the cage. I was thinking of doing the same with my shocks. What do you guys think? Can you think of any negative views towards this.
    Pic from PETERSENS.
    Mine would only be 4-6inches out the floor, behind the seat, mounted and protected on the cage. Just want to save money and work with what I got.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I think it's fine. I've seen it done several times before. It's just not practicle on a DD. But on a dedicated trail rig, I wouldn't hesitate for a second. Heres another pic of another guys.
  3. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I guess if you wanted to get really fancy, and wanted to do it on a DD, you could always hunt down some shift boots that would fit.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    :D i'm all about that idea...
  5. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    Not going on a DD, so not worried about crap coming through. Just more the damage they might get from stuff sliding and hitting them. I know, just don't let things slid around. Now that I think about it I could put them on the inside of the cage and protect them between the rear seat. eh? eh?
    Would they move around too much at the floor? I think they would move only 1/4 to 1/2 inch around the area.
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    They'll move around slightly, but nothing major. There should only be some slight flex movement from axle travel and very slight side to side, I would think. You have to think about the springs, their only going to let them move so much, but there will be some. I'd just cut something like the second pic.. sort of a pill shaped hole, but nothing bigger. You might even get by with a little less length.. but you would have to see what you application needs. Since you might have more or less angle on you shocks etc. Different suspension specs and all. But it's very doable.
    I like the idea a lot, hence having a pic handy.. but I still like to DD mine when I want. I guess I'm still "old school" on most things. I don't want to deal with the holes.. I still like to play in the mud as much as anything else.
  7. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Get some vinyl from the fabric store/boat store and have your wife/GF/mother sew you up a shifter boot to fit over the top and keep the elements out.
  8. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    do it like offroad design did it along time ago
    even if its a trail only rig cleaning **** out of the floor and inside still sucks
  9. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Everytime I come up with a clever idea, somebody's already done it. I was proud of that too.
  10. dreadstealth
    dreadstealth Registered Member
    Nov 8, 2006
    43
    fountain CO
    what about mounting them at an angle like you would run shocks. have a small crossmember thing that will attach both shocks under the truck and still have coilovers.
  11. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    I've been thinking about this too. Are you guys talking about attaching to a body mounted or frame mounted cage? That is potentially a lot of force to carry in a body mounted cage, is than an issue?
  12. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    I was planning on mounting them to the cage that would be frame mounted at that point.
    My shocks that I had before I had the blazer will not work by just angleing them. They are just too long to go that route.
  13. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    This is what I went with. Hope it works out.
  14. BGKYK5
    Nov 1, 2006
    5,936
    on the crapper...
    Looks great! Any more pics? That is a frame mounted cage correct? Any rubbing with the holes for the shocks that small - I would have thought the holes would need to be larger. Does it clear the rear seat? What does it look like from underneath - frame clearance, how did you mount the shocks to the axle, etc. Yikes that was a lot of questions, sorry. :)
  15. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    Don't forget about roof pipe flashing. That's what I'm using. Very cheap at Home Depot. They worked perfect for my setup with the furd front shock towers through the bed. -Eric
  16. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    Yeah frame mounted. Have not been able to check out the hole size for rubbing yet. Ther is about a 1/2 inch all around shock so I think it will be ok or just a little more trimming. Clears rear seat snug, angled it with rear of seat. Well they fit between the frame and wheel well and mount to the spring plate by brackets. It's good to ask questions, that's how I learn. :D
  17. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    Could only find this one were it shows the mounting spot.[​IMG]
  18. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    MrK5 did it and his look great. PM him.
