Shocks...To Boot or Not To Boot That Is The Question
Discussion in 'The Garage' started by Drey, Apr 27, 2007.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Im putting a DIY4X inboard kit on my truck(4-6 inch lift 35/12.50s) So Im gonna need some new shocks. I found some good Procomps on summit for cheap:D
    But Im worried this truck will see alot of gravel roads and them bigger tires will really throw rocks back under the truck I imagine. Would I be better of to run boots and not worry about rocks scoring up the shock shafts.
    I do know that water, dirt, and dust etc. get inside the boots and screw the shafts up anyway. What would you guys recommend?
    The shocks I was looking at were Procomp 3200s I think. Im considering steping up to some Ranchos with an adjustable rate though.
    The truck will be a DD, work truck, light trail truck, alot of muddin and snow wheeling.
  2. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Giv'm da boot
  3. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    I've never run boots, never had a problem. :dunno:
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i always were boots, but my shocks don't, they are nekkid.
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    On a 4x4, the shock boot is just going to get filled with mud and damage the seal. Run 'em without the boot.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    No boots.
    Harley
  7. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    no boots, but if ya do put em on make sure they're hot pink :D 80's style yea
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no boots for dis guy
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    No boots here either, I run on alot of gravel roads and no problems at all. Get a better shock than the pro comp 3000 thats what I have the 9000 aren't that much more and are way better.
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    no boots
    -Harrison
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Its interesting on this one; seems the factories have it right with the plastic tube open at free end, or in the old days, no boots.
    What do the racers run?
  12. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I had boots once. Never again.
  13. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Awhh, but boots are perdy. J/K :wink1: If you run boots thats one more thing you have to remember to check/clean after a run. If you're the kind of guy that goes through his rig with a fine toothed comb after each run, then I don't see what the big problem would be, if not, no boots.
  14. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I used cut down ones to hide the mounting of my KC lights once.
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Gravel & rocks can ding or dent the shock shafts. Off road racer go bootless as none of the shock they use even offer boots, but when a shock shaft is a hangy-down part it is usual to see some sort of deflector flap, like Rally cars use, under the truck somewhere.
    One of my old crew chiefs had a piece of plastic double zip tied to each shock body (body up mounting) and the lower end of the plastic was stuck thru the lower mount such that it could move up & down inside the mounts. Mounts fwd of the axle won't work this way w/o some mods.
    Were it me I'd run the boots, but cut them so that they can not form a seal on the shock body. That way they won't trap water or mud, but they will protect the shafts.
  16. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    x2- aint no reason to not have boots is there? I say run um. Hot PINK!
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You probably have the trick solution for whats currently available on the market, open the bottom end, same as new factory.
  18. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Weve got some heavy duty ABS plastic stuff at work I might try to zip tie that around the shock body and go down with it to provide some sheilding to the shaft. Either that Or ill just cut the bottoms out of the boots.
    Im not really worried about the front shocks just the rears. Mainly from the front tires throwing rocks under the truck.
  19. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    My boots cut my seals up as well. I say no boots. -Eric
  20. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It depends on what you run. I live in the desert. 60+ mph aint uncommon on a dirt road. I destroyed a set of rear un booted shocks in less than a year. Leaked like hell.
    I always run boots. My rear shocks usually look like they have been run thru a sand blaster.
    Hot Pink to match the drive shafts!
