  1. GMtrucklover
    GMtrucklover Registered Member
    Oct 29, 2001
    75
    colo spgs, co, us of a
    I am having a hard time finding shocks to fit my k5. The amount of drop and compression i have in the rear are limited because of the shocks. So what i was thinking was taking off the shocks entirly or maybe fabing a quick relase set up simular to sway bars. What do you guys think??
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    taking shocks off....no
    shock disco..........no
    You need longer shocks.
    http://www.doetsch-shocks.com/trucks.php
    You can pick whichever one one want. The longest ones are the 8403's. You can buy them from Summit part no DOE-8403 pretty cheap - check it out.
    -- Mike
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Find ramp to use.Take one end of shocks loose.Flex it out on ramp. Check length at both ends of travel.Rancho Etc. or parts house should be able to match something up.Lots of them have replacements for 2 & 4 in lift. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif If you want to move lower mounts for clearance nows a good time. /forums/images/graemlins/thumb.gif
  4. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    You could also buy them from West TX Offroad and support the site. PM thelakerat
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You have found the achille's heel of this truck thanks to the acid dropping engineers at GM. The only fix for this is redesigining the shock mounts, not longer shocks, not taking the shocks off or a disconnect.
    You can look around and see what most members are doing with the shock mounts by mounting them angled towards the center of the truck and do/buy the appropriate fabricated solution.
