Shocks
Discussion in 'The Garage' started by Greenie, Jul 21, 2003.
  1. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    My 89 K5 has the quad shocks in the front. The only difference is that one is longer then the other.
    My question is, since they are gas shocks and they naturally have pressure to expand them, can one shock be used as a compression shock and the other used as a rebound shock.
    This technology is used on desert race cars and trucks. When you have two shocks at each corner, one is used for compression and the other used for rebound. Do you think this will work for this application.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    Never seen no setup like that /forums/images/graemlins/confused.gif
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Like Bubba said, never seen a set up like this... and I have looked a lot of set ups in the last few months thanks to VORRA. Got any pics?
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    My 87 has that setup! I don't know the answer to the tech question, but I do know that it's not uncommon... Some trucks came from the factory with quad shocks up front! If you look at the inner fender on your truck, there's a half circle on the inner fender clossest to the frame where they cut out for the second dual shock mount! Hope you find the answer to your question, just didn't wqant you to feel it wasn't a factory setup! /forums/images/graemlins/thumb.gif
  5. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I should of clarified since I have a quad setup on my truck.
    Never seen no shocks setup with one only rebounding (like Shaq ) and the other one only drooping (should I? /forums/images/graemlins/rotfl.gif)
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hummm....maybe you can turn one set of gas shocks upside down so while one set is compressin, the other set will be reboundin /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif One more beer and im going to try it on mine /forums/images/graemlins/thumb.gif
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i had rancho 5000 shocks on my stock lift truck when i bought it. one had a thicker piston and expanded when i unbolted it. it had alot of push. the other was a thinner piston and stayed put when unbolted, but was hard to move up or down. i think thats something like what you described. im pretty sure they were set up like that to work as a team.
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    On these idiotic front quad setups, if you order the shocks that are replacements for the stock ones, then the shocks are either built/valved for the quad setup and you can't remove one cause it will mess up everything.
    Life is grand and horizons are broaden and mass bannings from FSC are reached when one becomes enlightened to the world of shocks past the stock Rancho replacements...... /forums/images/graemlins/rotfl.gif
    Hey 88Silverado, please UPS your beer to Bubba, it's making you wacky like Daffy.
