shooter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shooter, Nov 28, 2001.
  1. shooter
    shooter Registered Member
    May 24, 2001
    18
    Colorado,USA
    I have an 85 Blazer, with a tilt steering wheel. The tilt assy is worn and I can move the wheel about an inch in all directions. What do I need to replace and Where can i get the parts???
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Here ya go. Also many previous posts if you do a search....
    http://coloradok5.com/gallery/Daves-Pics
  3. shooter
    May 24, 2001
    18
    Colorado,USA
    Thank you, I printed it up along with the pics, and it will be very helpfull
  4. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    I dont know about a 85 but on my 88 there are two or three screws inside the colum that back out causing this play.I pulled off the wheel and took out the turn signal cam and back in there about a foot you can get to the screws.use a magnatised screw driver, pull em out and put locktite on.Oh yea it helps if you dony use your steering wheel to pull yourself in to the truck.Good luck.
