Shop Heat Help
Discussion in 'The Garage' started by JEBSR, Nov 28, 2005.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    As it is starting to get pretty cold in my area I am getting ready to buy a heater for the garage but need some input. The garage is 30'x45' (1350sqft). I was looking at a propane but it said that it take a 20 gallon tank of propane every 12 hrs. Way too costly as much as I would use it. Another option I found is from jegs jegs blue fan with heater attachment Has anyone tried these? Don't really care for the bullet heaters as they are loud. What are my other options :dunno:
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I don't think 5,300 BTU isn't near enough to heat your shop. I doubt it's really enough to warm you even if you sat right in front of it. Even a 55,000 BTU would be a little small, but it would work. My 40x60 shop is not insulated, and I use the 150,000 BTU bullet heater and it never really warms it up in there, I just have to point it at where I'm working. Also check the CFM output as it will effect the amount of heat also.
  3. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Best bet might be to find a good used pellet stove, easy to plumb and can easily heat 1400ish S.F.
  4. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    My old neighbour used a big swimming pool heater and plumbed in piping all across his garage. worked like an old boiler and was extremely successful.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Wood burner.
    Go to your local high school's woodworking shop and tell the teacher you would like all the scraps they throw out. Deliver around five 55 gallon drums and let them fill them up. There will probably be more oak scraps than anything else and for the small sizes they are, they will burn better and hotter than any log you can get.
    I've been using the drums from the school and taking the scraps home for the burner in my shop. If you have some used oil on hand, pour some in the stove first and then some newspapers with the scrap wood on top. Lastly, I throw a log on top of all that just for added measure.
    Wood is cheaper and can be found anywhere. Check out your local lumber yard for their scraps, too.
  6. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I just use the old fuel oil furnace that was in my trailer. With some creative ducting it can be done without too much trouble. It heats a 24'x60' building with 10' ceilings. Trick with high ceilings is to install a couple cheap ceiling fans to blow the heat down. Often you can find these type furnaces in the traders guides.
  8. KTEX
    KTEX Registered Member
    Nov 8, 2005
    19
    wylie
    Those blue fans are great in the summer,but the heater does not work very
    well unless your standing 2' in front of it.
  9. 87_k5_silverado
    87_k5_silverado Registered Member
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    That there "Blue Blower" is JUNK....at least the heater attachment is. I have one and I only use it for the fan in the summertime; as my Saint Bernard likes to hang out in front of it. I paid like 40 bucks for the thing and another 20 for the heater attachment. The fan itself kicks *ss.....I would buy one though. I use mine all the time. I hope this ramble helped.......
  10. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    eh...waste oil burners...
    I use 2 55 gallon drums converted to wood stoves,one is an "upright" version that top loads,and has 3 -2" pipes that go down from the top of the barrel to let in air for combustion (a copy of the "Tempwood" stove )--its much safer and you can cook on the flat top of the stove,something thats difficult to do on the other one,thats made into a stove using the commonly available kits at hardware stores..or by using a cast iron chimmney clean out door and a hinged flap for air intake..the toploader sucks to empty the ashes and nails..have to lift them out the top!--but you only need to do it once a year,its not that much of a pain..takes up less space too!.
    Sparks can jump out of the air inlets on the horizontal stoves,also any gas vapors will tend to stay near the floor,and could be more easily ignited if any fuel is spilled in the shop..while the vertical "upright" ones pipes could be ducted to outside air if desired to prevent such a scenario..I've never had any troubles with my stoves while working on a vehicle,though while rebuilding a few carbs some gas and vapors were worrysome..but no explosions or fires..(yet :blush: :rolleyes: )..
    I like the "Mother Earth News" waste oil burner..but its basically just a wood stove with a copper tubing wrapped around the stove pipe with oil dripping on a hot iron surface..I have burned waste oil in my stove for many years by simply letting oil drip the same way on some old tire chains mounted inside the stove near the stovepipe outlet--they get red hot from the wood,and the oil flow is adjusted b a needle valve,makes a "POOF" every time a drop hits the chains..
    I've also just poured a cupfull at a time in the stove,as long as you have a good draft,it burns cleanly with little or no smoke..takes all day to burn a few quarts though,in a waste oil "drip" setup....too slow if your trying to dispose of a lot of oil quickly,like at a "real" shop..
    Two or three things I dont like about the waste oil heater--not many "good" water heaters are in the dump!..every one I've seen was junked for a reason--IT LEAKED!!...so good luck finding one--whereas one used for a woodstove is easy to weld a patch on..also,21,000 BTU's isn't squat!..(5,000 btu's is what those electric "ceramic" heaters put out..makes a good handwarmer,thats about it!)... :rolleyes:
    It would do little or nothing to help "heat" my garage--both the stoves I have put out over 150,000 btu's,and at 25 degrees I'm lucky to get it 50 degrees or warmer with BOTH stoves going!(uninsulated steel quonset garage,20x40 ft,13' ceiling)..also I dont see any way to control the oil flow,or shut it off??..and some new synthetic oils won't burn good period..one gallon of it mixed with 54 others of plain petrolium oil will gum up the works..
    I think I'll be looking for some water heaters to replace my barrels when they rot out,since they say they are thicker..I get free pallets from factories and places that sell gravestones,and dead trees from the woods out back..
    I have yet to ever pay for heat,despite the fact I do have an old forced hot air furnace I had to weld up the cracked firebox in --came from a friends house--its 110,000 btu,sworks great--but I can torch 20 bucks of fuel in it in one day..more than I'd make farting around in the shop--so I stay in the house a lot when its cold!.. :doah: :( --or spend as much time feeding the stoves as I do working.. :crazy:
  11. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I use a little propane radiant heater in my two car garage. I got this from Northern Tool . I don't run it continously, just when I'm actually working in the garage. Does a great job on taking the chill off, and if I leave it going (it does come with a themostat) it will burn my bald spot :D
  12. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Have a wood stove in my garage...
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    the used oil heaters are unhealthy as hell....leakage from the stove burning cancer causing stuff isnt the best idea for an enclosed shop
    how about a corn pellet stove... good ones burn about a bushel a day at around 2.00 a bushel... in the size you spec'd
  14. 87_k5_silverado
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    ditto on the corn stove............
  15. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    get a double barrel wood stove. it's a kit that uses two 55 gal. drums.. or get some electric radiant heat to hang above your work areas. it will be like a big toaster with a stainless reflector. that way your tools and work area get heated as well
  16. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    wood stove with a fan behind it is what i use in my garage in WA. the little heaters are good if u put them facing ure toolbox so it warms up the tools :D
  17. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have a 85,000Btu slamander in my garage. Runs off propane though, which some people don't like. It has served it purpose well though for the two winters i have had it.
    Doubt i will ever need it in So-Cal though so one of the neighbors will buy it
  18. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I have a small 1000 sq ft shop with 8' walls and 4" insulation roof and walls.
    I use 2-4000 watt (I think) heaters with a couple ceiling fans. Keeps it cozy, and can heat up to 70 if I want it to. It costs a little more than the propane I had in there, but with the price increase this year it may be cheaper. Also it doesn';t create the moisture that the propane does. Keeps things from rusting. I wouldn't go back to fuel. The heaters cost about 145 each. And run off a 20amp circuit.
  19. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    u coming to socal? sweet diego?
  20. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    We rep a product from a company called Solaronics. They make a product called Suntube IV. They are available from 40,000 to 200,000 btuh. The tube lengths are from 10 - 70 feet in length. You can get them either with Natural gas or LP/Propane. To find your local rep go to www.solaronicsusa.com or you can call 1-800-223-5335
