short bed 3/4 ton and towing
Discussion in 'Tow & Trailer' started by supersize75k5, Aug 16, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have my 72, it is a 3/4 ton 2wd with a 454 and t-400 and I am making it a short bed.."dont ask why"
    Anyways, if I keep the spring rate the same, as well as the general set up, should or can I tow my buggy once it is done?
    I have been told yes by many, but I want to hear it from you guys. I will be happy as long as it tows better that a lifted blazer.
    any input or comments are welcome /forums/images/graemlins/ears.gif
    -thanks, shawn
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Should pull fine. I have hauled pickups on my trailer with my 10" lifted K5 with boggers and haven't had a problem. The 72 probably would tow better than any K5.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I'd say it will be ok for pulling a 16-18' trailer as long as it is loaded properly. Longer trailers or poorly distributed weight will affect shorter wheelbases faster than longer wheelbases.
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Have a similar question so I'm sticking it in this thread. My DD is a 85 3/4 ton 4wd. I was considering using it for towing my bigger truck. I'm probably gona end up building a trailer that my truck will straddle the axles so the trailer itself will carry the bulk of the weight. I was also thinking of making the trailer a gooseneck to get some more stability out of the entire setup. I'm not a towing guru so am I missing something?
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    I'm going to burst some bubbles here, sorry... /forums/images/graemlins/frown.gif
    You will have your hands full trying to tow a K5 buggy/truggy, period! Short wheel base non-extended cab trucks are going to tow like A$$ and I do mean like A$$. There just is not enought wheel base to pull a heavy rig steadly. I will tow it, but it's going to be very unsafe and very ugly.
    I have towed with my K10 4x4 1972 truck, only one time, and I had a Toyota on the trailer on the back of my truck, and I almost went for a ride on it's own. Too hard to control.
    I am not the towing police, but I would not recomend this setup to anyone.
    And Shawn, I am not picking on you this time! /forums/images/graemlins/doah.gif
    Rob
  6. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    /forums/images/graemlins/rotfl.gif
    the reason I asked was to hear what was needed..I can always get rid of the 86 to get a long bed /forums/images/graemlins/pimp1.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get a crew cab. My long bed truck pulls alright, but the longer, the better!
  8. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    cant...I want to daily drive what I tow with...a crew cab would hang past the drive way...other wise I pay for storage on it
    they might consider a crew cab as two spaces /forums/images/graemlins/rotfl.gif
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You "have" your shortbed while towing, Just get this [​IMG] and tow the buggy and the short bed at the same time.
    For those wondering, it is only 9K on ebay with a buy it now of 11K.
  10. 1970mustang
    1970mustang Newbie
    Aug 18, 2004
    3
    I don't know if this will help but I've done a lot of towing with two trailers one is a 18' car trailer and the other is a 19' coverted travel trailer frame made into a atv trailer that hauls 4 700 pound atv's. I've used my 92 F-150 ext.cab short bed to tow both and it tows them great as long as they are properly loaded. I have also use a 87 F-250 reg cab long bed and it will tow both with a more secure feeling than the F-150. I believe that is becuse of the bigger brakes and stiffer springs. I have also towed the car trailer loaded with a 76 K20 with a 83 F-150 with 6" lift and 35's. We didn't have the trailer properly loaded and at 65 mph the trailer swayed so bad it sent us across two lanes of highway and almost into the median. We almost learned the hard way you need 60% of your weight forward of the trailer axles. I also towed the car trailer with a 04 F350 Crew Cab Dual Wheel Diesel. It was pure heaven. You could pull the trailer 80mph and forget it's back there. Just so all the tow vehicles aren't Fords. Before I took apart my 85 K10 Long Bed I used it a couple of times to pull the atv trailer. It pulled it a little better that my F-150. But it had stiffer springs than my ford did. Just remember to properly load your trailer.
  11. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I used to have an '84 K10 short stepside that I converted to 3/4 ton and lifted 4". I pulled my 4K lb. Jeep on a car hauler trailer. Towed quite well actually. Buy my crew cab and towing will be one less worry on your mind.... /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  12. kennyw
    Jun 9, 2002
    13,224
    94
    A 2wd 3/4 ton short bed will be better than a lifted blazer for towing any day /forums/images/graemlins/thumb.gif It will never be the greatest thing in the world compared to a crewcab dually though.
    Have you thought about making an extended cab short bed out of the truck and keeping the wheelbase the same?
  13. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I like projects but I would shoot my self in the foot on that one /forums/images/graemlins/screwy.gif
  14. kennyw
    Jun 9, 2002
    13,224
    94
    Well there are coach conversion companies that can do all the hard parts for you /forums/images/graemlins/tongue.gif
  15. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a short bed 98 4wd and tow my jimmy constantly. Keep the spring rate and spent your money on a set of Air lift bags, air them up when you want to tow, keep the ride comfortable when your not towing. Very easy project. I spent extra on the onboard compressor and guages for convenience. /forums/images/graemlins/laugh.gif
  16. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    Do the Air Lift bags affect your rear tire clearance? I want some for my 1990 Burb, but I am afraid my rear tires will rub (33x12.50 on stock rims).
    Thanks!
    Richard
  17. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    When you air up the bags it actually lifts up the entire truck bed giving clearance between the tires and the fenders. But without a load the rear will act like a big spring affecting drivability and stiffen the ride up substantially, but with a load the truck drives like a caddilac, and thats not an overstatement. /forums/images/graemlins/k5.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you are towing your Jimmy with a shortbed 1/2 ton, you are dangerously overloaded.
  19. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    Sorry I wasn't clear about what I was asking. /forums/images/graemlins/smile.gif I have plenty of clearance for the 33x12.50 tires now. But the air bag kits I have seen bolt *outside* the frame rails, and it looks like they come very close to rubbing the inside of the rear tires. Since I have these 33x12.50s, I am worried that the bags/brackets would rub the inner sidewall. Do you know what I mean?
    Thanks!
    Richard
  20. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yep, know exactly what you mean. But hey also make ones that fit on the spring pack themselves.
