short bed on blazer frame..
Discussion in 'The Garage' started by bryguy00b, Dec 10, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i may wind up doing this swap.. as my body gets worse..it will do for a while..but as my last mod i will probobly want to do away with the body all thogther...my question is..will a short bed plus the cab fit on a blazer frame? or would the bed have to be shortend? i know backyardbiult has done this...did you have to do anything speacial? thanx!
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The bed would need to be shortened to fit. I have seen it done a few times and it is sweet.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    For the most part its a bolt on deal.Build a crossmember for the rear cab mounts and shorten the bed and yer good to go.There is a little more to it than that but thats basicly it.I chopped 13"off the front of my bed. /forums/images/graemlins/grin.gif
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Like frizzlefry said it is basically the crossmember and measuring to cut the bed down. Good luck when you do, do it.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    does any one have a pic of that..the cross member that is? thanx
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I used the crossmember out of the truck that I got the cab off of.If I have time later I can snap a pic. /forums/images/graemlins/grin.gif
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ohh ok i see...but yea a pic would be sweet!...i dont think i will do this body swap untill i have a worthy setup under neath the truck worth swaping a body for though! lol...
  8. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I found a pic .Its not the greatest but I think you will get the idea.You can see how the crossmember now sits on top of the frame rails instead of between them like on the truck. /forums/images/graemlins/grin.gif
  9. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    I take it your cab is from the '74 C20. What year blazer frame is it on?
  10. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    It was an 81 K5 /forums/images/graemlins/grin.gif
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so if i was doing this swap...i would see wear the cross member needed to be?
  12. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Yea ,thats the 2wd crossmember right above the mufflers sitting on top of the frame.
