Short life on wheel seal??
Discussion in 'The Garage' started by jwduke, Mar 8, 2004.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Any ideas why a rear wheel seal, would die in a few hundred miles? I thaught I was really careful installing it.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well what gave out on it? is it possible the axle shaft is bent or has some surface imperfection that ate the rubber part of the seal? or did the housing of the seal spin inside the axle housing?
  3. jwduke
    Aug 25, 2001
    721
    I used emery cloth on the area where it runs.....
  4. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    The surfaces on both sides of my rear axle have seen better days and the new seals i put in 18 days ago started leaking 16 days ago(I didn't drive it 17 days ago).
  5. Confedneck
    Nov 1, 2002
    5,236
    i just noticed its a 14bff...
    we had the same problem on chevy4wd's truck.. for some reason the timken seals wouldnt last.. put a chicago rawhide in it, and its fine.. what brand seals are you running, hubs staying tight??
  6. jwduke
    Aug 25, 2001
    721
    Humm, they were Timkin seals, I got 'em at O'Rellys.
  7. Confedneck
    Nov 1, 2002
    5,236
    well, iirc, timkens have a warranty.. so get it replaced, then trade it out for a different brand.. see if that works..
  8. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    did u put any gear lube on the seal before you installed it?
  9. jwduke
    Aug 25, 2001
    721
    Yes I did lube the seal
  10. Confedneck
    Nov 1, 2002
    5,236
    chance the seal spun, or is twisted and not seated properly in the hub?
  11. jwduke
    Aug 25, 2001
    721
    No, it fit tight. I had to use a seal driver to install it.
  12. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Leaking wheel seals on a FF axle are caused by.
    Groove on the axle tube where the seal rides.
    Improper installation of the seal or the wheel bearings not set up correctly.
    Wrong seal is another possibilty.
    Raise the wheel and see if the bearing is loose to start with.
    If that seems ok you are gonna have to take it down and see what is up.
    In any case the hub has to be removed to replace the seal and clean the mess.
  13. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    If you used emery cloth on the area where it runs..... You might have scored the surface to much, try to polish it smooth. I also agree Chicago raw hides are a better seal.
    Bill
