short shaft th400 out of 2wd dually?
Discussion in 'The Garage' started by sandracer0004, Jan 28, 2004.
  1. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    hey i found ashort shaft th400 out of a dually for 250bucks with 55k on it? will that bolt up to say an np205 with out major mods?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    only if its a 4x4 one, 4x4 are the shgortes version of any model of tranny and dont have output shaft housing, so if it has an output shaft housing then it is not a 4x4 tranny lol, you said is 2wd so answer is no,
    2wd is not 4x4
    its pretty basic
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Short shaft 2wd WILL fit a 205 t-case.
    Short shaft 2wd will NOT fit a 208 (shorter) or a 203 (shortest).
    I am 99% sure of this.
    John
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I'll second that a short shaft 2WD bolt on yoke TH400 shaft WILL work and is the same length as the 4WD version . Note: I think the shaft length changes on the 1985 ( round pattern 205's ) and up 4WD TH400's . Tom
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I also heard the bolt on yoke style 400 would take a 205. Somebody posted the shaft length awhile back, but I don't have it. I have a 2x 400 with my 205. I measured the output shaft and it was the same as the 400 the t-case came from. so, it's in there!
