shortening a driveshaft??
Discussion in 'The Garage' started by chevy_mud_84, Jan 18, 2006.
  1. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    i just put a th400 and np205 in my short box pickup, and it came outta a long box truck so i have the rear dshaft for it but it's too long so i was thinking of shortening it to the right length in my shop class at school. How hard would this be to do?
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    my local drive shaft shop would be about 50 bucks with balence job also.
    and the ends are pressed in to the tube just a bit and then set in balencer/lathe and checked for true and if good then welded . lot more than people think.
  3. chevy_mud_84
    Feb 28, 2005
    89
    i was thinking of just cuttin out of the tube what i dont need and then putting it in a vice and setting a level on it until its straight and then tack welding it then checking it again and then fully weld it.
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    If it's not done right, and balanced it will more than likely give you a lot of vibration going down the road.
    Rick
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    actualy thay make sure the ykes are level with each end. i watched them do it and it isnt that easy if you want high speed smothness.
    not saying you cant do it but it was vary specific when i watched them build my last shaft from scratch.
  6. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Its hard to do right,easy to do poorly. If its an offroad only truck than sure give it a try, anything on road spend a little $ and have it done right. Shortening is cheap anyway.
    Cutting the tube in half and re-welding wont work, the shaft will twist off at the welds.
  7. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    ive done my own before but i built a jig to do it to verify everything is in allignment. if you are only doing one shaft then have it done at a shop if you plan on doing a lot of shafts build an adjustable jig
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I have shortened and spliced a few shafts. OFFROAD use only really. I took 2 peices of angle iron and ran the length of the shaft over the splice on each side to hold it straight then tacked on each corner before welding. Not really a "right" fix but got me on the trail to go playing.
