shortening a longbed: few ??
Discussion in 'The Garage' started by 89Burben, Sep 19, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    When shortening a long bed frame is it more desireable to move everything forward and then get a longer shackle with the shackle flip?
    OR
    cut the frame in the middle and gusset it?
    thanks
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    Ithink it would be stroger to move the hangers and get a longer shackle and easier to how much are you going to cut it down???
  3. 89Burben
    Jan 3, 2005
    98
    CT
    wanted a wheelbase of or around a shortbed pick up......so moving the axle about 14" ahead
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Cut the 18" or whatever out of the frame behind the cab.
    Then everything else will still line up correctly.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    out of the middle of the frame. The frame drops way down towards the cab and I think it would mess stuff up
  6. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    a guy i know did it and was cut right behind the cab and boxed in. it works great for a few years now, he said it was pretty easy really.
  7. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I did it on my truck when I went to 63" rears. I slid everything forward on the frame to the length/wheelbase I wanted to end up with then I cut the bed to match. Mine is in the middle of a long bed and shortbed. I wouldn't have even thought about it if I had to cut and weld the frame, at that point just get a shortbox frame. If you have enough lift and setup bumpstops correctly the frame being lower won't hurt you except for a possible limit on up travel. My tires would personally hit the top of the bed's wheel wells before the axle could even touch the frame and I'm only running 35's.
  8. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
  9. 89Burben
    Jan 3, 2005
    98
    CT
    im not qualified to see the pics :mad: anyone got any links?
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    dont cut the frame, thats just stupid. move everything forward. its quicker, easier and stronger. its very easy to get everything in the right place height wise.
  11. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    http://www.73-87.com/7387garage/chassis_suspension/lwb_to_swb.htm every where i've read told me to z cut the frame and remove 12 in the middle and 8 in the back or 14 in the middle and 6 in the back but these were all sport trucks or low riders what ever you want to call them and not rock crawlers or any of that sort i havent done it so i really dont know
  12. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Cut the frame just behind the cab in the long straight section. Much easier, you'll only need to modify the driveshaft length and welding the frame is no big deal. Use a diamond shaped (rounded corners and rosette holes in the middle) fishplate for added security if you are really concerned. It's been done a thousand times; you guys worry too much.
