shortening a lwb truck to Blazer length?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Nov 27, 2002.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Does anyone know of anyone who has done this? I have sorta been looking for a junker bodied K5 frame to build into a buggy sorta affair, but no luck yet. I have a LWB 3/4T that is sittin here. Is it tough to shorten the frame to around 106-110", maybe take a length out of the center of the frame and put it back together? I am contemplatin either a tube buggy idea, or a pickup cab type/ flat deck but heavily modified. ie widened Jeep hood, no front fenders, topless etc. It will be a long term project, but just thinkin..... /forums/images/graemlins/smile.gif Usually bad news when I start thinkin like this...
    Mike
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's been done a lot, but I have a blazer and I am trying to lengthen my wheel base to 110-115, more stable and fits most of my trails.
  3. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I shortened my crewcab longbed to about Suburban length. I took out 23 inches by moving all 4 spring hangers forward. Use a 10mm drill bit and 10mm bolts to put it back together. I used grade 8, but some people tried to tell me to use grade 5 so they would flex instead of brake. I would rather have the stronger of the two. [​IMG]
  4. Thumper
    1,582
    Alberta Canada
    Now that is cool! What is your wheelbase now? How do you find it on the trails? As compared to a Blazer wheelbase length? Is yours as long as a regular cab pickup wheelbase? Just lookin for a fun project to do that works well. Thanks for the pics!
    Mike
  5. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I have no idea what the wheelbase is. If I knew the original then it would be easy to figure out(subtract 23 inches). I still don't have it completed so i have no idea what it is like on the trail or road. I need a wiring harness, steering column, gas tank, front and rear shafts, and a roll cage at least.
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Ryan,
    Very cool idea. What do you plan to do for the bed area?
    FYI:
    73-87 long bed pickup = 131.5"
    73-87 shortbed pickup = 117.5"
    73-91 suburban.......... = 129.5"
    77-91 crew cab lg bed = 164.5"
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Cool truck. What gas tank are you going to use?
    You've got me thinking
    I was wondering what it would look like moving springs up and cutting out the wheel hump in frame. It's hard to forsee any clearance issues there with the lift in place. Your departure angle is gonna be great!!
  8. Thumper
    1,582
    Alberta Canada
    I was looking at the frame on the lwb pickup and see that it drops at the back of the cab and is a little lower from there forward. If a guy cut the frame, and welded it on straight, it would give the equivalant of a 3-4" lift... dunno if you caught what I mean, but I am cutting the bed off the truck this weekend and checking it out a little closer.
    BTW thanks for the wheelbase numbers. Might help!
    Mike
  9. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    wheelbase would now be 141.5". The bed will be a flatbed made with 2" tubing for the outer edges and I am not sure about the bed surface yet. Going to put a tool box behind the cab and a spare tire mount on the driver's side that will hold the tire upright. Hoping on using a 40 gallon 'burb tank mounted just forward of the rear axle.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    mine is c30 cut down to shortbox length.
    cut and spliced between the cab mount crossmember and the steadybearing crossmember
  11. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Hey mj, do you have any pics of your truck like this? I just bought a 88 crew cab and was wanting to do this. Sorry, guys not trying to steal your post
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
