Shot gun help?
Discussion in 'The Lounge' started by Citizen Rider, Nov 26, 2006.
  1. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I have a Smith and Wesson Model 1000 12g shotgun. This was passed down to me by my grandpa. When i shoot it, the slide doesnt recoil enough to launch the shell out of the gun. I have to manually pull the slide, and remove the shell.
    If memory serves me well, it did this a few years ago, and all it needed was a good cleaning. Well the cleaning didnt do anything.
    Does anyone have any ideas, its not making any sense to me.
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    See if you can get an exploded parts drawing from Browning, or try www.Brownells.com for a parts drawing. Your shotgun may use O-rings on the gas piston which need to be replaced after a while. You might need to buy some new o-rings and install them, or take it to your gunsmith and have him do it.
  3. 68MUDSTUD
    68MUDSTUD OCD with shiny things
    Sep 30, 2005
    9,448
    MT
    Lube!!!
  4. Roland_Jenkins
    Roland_Jenkins Registered Member
    Apr 14, 2006
    58
    Newport Washington
  5. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Your gas port could have some obstruction. You should be able to see it in the barrell. It'll be a little bitty hole that vents gas to the piston. I'd start there.
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I had a Savage 720 that wouldn't cycle. Turns out I was just "limp wristing" it. With a hard hold it cycles fine. Dunno if that helps........
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    This was basicly the problem. The piston was not aligned with the hole in the barrel. Lined it up and shell shot right out.
  8. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    I've heard of limp-wristing an autoloading pistol, but not a shotgun! :doah:
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Eh, I may be just imagining it, but it seems if any of the recoil is soaked up by moving the actual shotgun, it wouldn't cycle as well.... maybe?
