Should a tow hitch be bolted to frame or welded to frame..
Discussion in 'The Garage' started by jakeslim, Mar 17, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ...because mine is welded(po) /forums/images/graemlins/doah.gif
    is this a problem?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    welding would be strongest, bolted and welded would be ultimate
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    ok, because someone here made a comment about that it should be bolted, can't remember who though or what post
  4. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Mines bolted on from the factory, welded is fine but it can't come off. I had to drop mine when I put on my body lift.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I'd prefer bolted. I hate anything welded to the frames except for the steering box reinforcement plates. /forums/images/graemlins/thinking.gif
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    just want to make sure its safe. I plan on using a hitch shackle for "those" moments of "stuckness"
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Depends if its a stock truck with a little mods or some wierd bobbed fabrico contraption. I'm just going to weld everything on mine, crossmembers and substructures and such, the hicthes too
  8. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    hey, shouldn't you be in the Lounge? who let you out /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
    oh wait, who let me out! /forums/images/graemlins/histerical.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that.
    I'm the one that said it should be bolted.
    If I were you and didn't know the history of the trailer hitch, or who welded it on, I'd cut if off and bolt a regular hitch on.
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    My posts in the lounge are about a mile and a half long and my posts in other forums are one line, that may be why you never see them
    I also don't do emoticon posts or reply to things I have no idea about
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'd bolt it on, unless your a good welder and made sure you welded it on there good. Just my opinion /forums/images/graemlins/dunno.gif
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    The hitch on our dump/tow rig is welded on. It needed lowered so there are some custom brackets I made and just welded everything together. It handles our 2,000lb trailer loaded with the 5,500lb backhoe quite well.
  13. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I'll 2nd that.
    Exactly, you know the strength of the bolts, you have no clue how strong that weld is.
  14. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I'll 2nd that.
    This is my idealogy as well. I prefeer them to be bolted.
  15. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Welded is fine just look at the welds and make sure there is suffecent penetration. If your worried about it drill some holes and stick some bolts in as well. Welding on hitches is easier IMO in some instances.
  16. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks for everyones responses. the welds look good in my
    no-nothing-about-welding experience.
  17. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    bolted...welds can break easier, our club doesnt even allow anyone to run a welded hook..
  18. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I disagree. A welded seam if done correct will be just as strong if not stronger than a bolted one.check out a backhoe bucket sometime. On some of the bigger excavators the teeth can experience ripping forces well over 25 ton and they are welded on.
    When in doubt feel free to bolt something on. But saying any weld is weaker than a bolt is wrong..I've seen bolts from recovery hooks pulled right through the frame (front factory hooks on a late 70s blazer).
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If welded correctly it will be many times stronger than the metal the trailer hitch is made from (or the frame itself.
    Unfortunately there is no practical way to verify this, so cut it off and bolt a hitch on correctly.
  20. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    well this clarifies things... /forums/images/graemlins/doah.gif /forums/images/graemlins/dunno.gif
