Should an IFS truck CV axles spin in 2wd?
Discussion in 'The Garage' started by Pookster, Jun 29, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So on these newer IFS rigs that still have a manual transfer case- When you are in 2wd, is the CV still supposed to spin? Im thinking this can cause some unncessary wear- Would manual hubs help? Or is the problem that it shouldnt be spinning anyways, and I have some other issue on my hands?
  2. beatup4x
    beatup4x Registered Member
    Jun 17, 2004
    7
    Mountain Home AFB, ID
    Yep, with the ifs your cv axles will still turn because the splined end of the axle directly engages with the hub. I don't know of any manual hub kits, but I don't think it is really necessary. I had a 92 1/2 ton with 280k miles and replaced both axles because I cracked the cv boots and let them run dry causing damage to the joint.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the actually "lockout" part of the front axle is before the CV shaft. the CV shaft is kinda like a front wheel drive car where it connects to the wheel hub.
