Should I buy a K5 Chalet for $600?
Discussion in 'The Garage' started by mountainexplorer, Oct 20, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Hell yeah you should.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    This one seems to be a rustbucket. But what are these things usually worth or selling for?
  4. bowtiepower00
    May 11, 2000
    924
    AZ
    You don't see them very often, but IIRC, the ones that I have ranged from a grand or so in need of work, to 3 or 4 grand in good shape.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    FWIW that's not a chalet, it is a blazer with an aftermarket camper top on it.
    Back in the day Tis company: http://www.fourwheelcampers.com/ made camper tops for the blazer, that is what's on there, not the factory Chalet top.
  6. mountainexplorer
    Nov 14, 2001
    4,903
    Thanks for the info. I hadn't really seen enough Chalet's to really pay attention and think about if it was truly a Chalet. I wonder how that affects it's value. Still seems like a decent deal though. I may still go check it out.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That looks just like the one I used to have.
    For what it's worth those are not framed with wood. I found out that they are framed out of 1x1 square tube aluminum, sides & top.
    So if the exterior is not in bad shape they don't require much to redo the interior.
    No jacks either, unless ya make some. Or get 3 other guys to help lift that heavy SOB up.
    I wish that I had the room to have kept it. But I did get about $200 for the aluminum.
  8. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    get it .... pickup cab and supershortbed it
  9. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    On the one I had that would'nt have worked. It is made for a K5.
    There was no front bulkhead, it's a pass through pop up.
  10. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I think that would be great. Paint the outside to take it out of the seventies and update the interior, put the bikes on your trailer and make a weekend of it.
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The Chalet extended past the rear of the truck and had taillights in it. I'd buy the camper by itself for 600 and cut a Burban up and put it on the back.
  12. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    For $600, I'd buy it right now - except I'm in New York State and have no way - wihthin reason of getting it here.. I've got two campers on K5 diesel Blazers - a Hallmark and a Chalet. As other's have mentioned, that camper is neither. One thing the Chalet has that no other's do - is a front roof-line that matches the contour of the windshield. Chalet is also heavy - legally - too heavy for a K5 once is as loaded. An empty Chalet weighs well over a 1000 lbs. Then, put some food, water, people, equipment and luggage, etc. - and you're over the original 6100 GVW rating. The Chalets were dealer installed and the GVW was upped to 6500 lbs.
  13. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    worst case scenario you get a blazer and some money back for the scrap aluminum. go get it. the ad says best offer, that means cash talks. He'll take less.
  14. mountainexplorer
    Nov 14, 2001
    4,903
    I can get it for 500 bucks. Has water in the oil though. I'll wait a while and see what happens. I just sold my '83 6.2 Diesel... I should be rebuilding a couple motors, but knowing me I'll just buy more trucks.
  15. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,607
    602
    Hooper, Utah 84315
    Yeah it does look like the fleet is getting a little low:D
