should i buy it bbc????
Discussion in 'The Garage' started by HELLBENT DESIGNS, Jan 19, 2006.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    looking to upgrade the 454 in my 1967 gmc, bought a mercruiser ramjet mpfi setup. i asked a gearhead buddy if he had any extra rectangle port chevy bbc heads. he replied, on my 440 you should buy it! ok here is the deal! he had this engine built about 10 years ago for his drag car. parts are a 60 over 454 4bolt main block, trw 10-1/2 to1 comp. forged pistons, forged 427 crank, new ls7 rods, new ls7 rectangle port heads with manley severe duty valves. the guy came into some money so the engine only has about 10 miles on it. he quickly upgraded to a 509 then a 632 all aluminum bbc setup 1200 hp on fuel no nitrous or supercharging, alcohol etc. so i know the engine is done right. he ordered the biggest solid roller cam that crower listed and was running fast, 9's i think! his current setup runs 7.50'sin the 1/4 at MT altitude, anyways i would have to do a cam change and valvesprings. everytime i add up the cost of a performance engine it makes me sick:doah: this engine is a bit much for a dd but i think i can get it for about $2000 which includes trading him my standard bore 454 4 bolt block and eagle 4340 crank. any help guys:dunno: thanks
  2. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    faaaaaast.....
  3. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    :dunno:
  4. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    thats all I got for help lol... i want one!
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Divide Ride or Bust! :bow:
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Is the 67 going to be an offroad truck? I say that you stick with what you have and use the 2k on something else. You don't need all that motor unless your doing sometthing REALLY crazy. Those heads are made for high RPMS. You wont be doing that on the trail unless it's for an occasional rooster tail to cover your buddy behind you in mud :D
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It might be "built right" for a 9 second drag car....but it sounds a little backwards for a truck application:
    1. Smaller stroke, less torque
    2. Biggest cam usually means it's setup for high rpm HP.
    3. Big square port heads generally mean the same thing.
    For a mud truck, it might be a good choice...but I don't get the impression that's what your doing. The cost and aggravation to convert it to something with more bottom end power probably makes it a poor choice.
  8. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    If its been sitting for 10 years it could have some problems. Rust, leaky gaskets, etc. The 10.5:1 will require premium fuel. It cant be rebuilt since its .060 over already. You could probly change the cam and run like a Performer RPM intake and a decent carb and be OK. Just know that the fuel is gonna cost ya...
  9. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    yeah for a light car it would work well! if i built my current extra block up i planned on a basic 9 to 1 comp. 496 stroker. this truck isn't a mudder and trail use will be very limited. if anything using it to pull the trail rig would it's main use other than weekend drives, that's the answer i was looking for. thanks guys:waytogo: besides this looks funner:D
