Should I buy this Compressor.....?
Discussion in 'The Tool Shed' started by BigBen, Sep 29, 2006.
  1. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I don't have air in my shop yet.
    I've wanted a 60 gallon for a while, but was going to settle on 30 for price.
    I really don't konw that much about compressors, so I figured I would ask here.
    A friend of a friend just upgraded and has this Craftsman up for sale for $225:
    What do you think?
    -Ben
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I guess that is a pretty good price. But from what I have heard, oil-free compressors are not as reliable as their oiled counterparts....
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Not a bad price. If it's two cylinders, it could be dual stage (quieter) or just bigger ... noisy fricken things. I had the red-tank (i.e. low end) version in that capacity and it was a POS, ended up repairing it out of warranty, and when it went out again I just bought an el-cheapo from HF for like $175 on sale.
    -- A
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Id save my coin and buy a nice one
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Depends on what you are going to use it for. I have a 30 something gallon from Home Depot that works great, but I don't paint or blast often. Mostly just for airing up tires and using air tools.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    unless those air tool are sanders or grinders, he really should check out the air consumption of what tools he wants to use and then decide. I spent almost 800 on mine and now that works properly I am really happy with it. It'll run almost anything and I can say my Brothers 1200 dollar Ingersall is very close to the same output...
  7. cbbr
    Jul 17, 2004
    14,681
    Good point. Mine does ok with grinders or sanders, but is not great and there is some waiting involved.
  8. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The oilless ones are LOUD. But they do work better in an unheated environment, unless you use synthetic oil in the oil type. Like said, look closely at the cfm ratings at the higher pressures. The low pressure ratings don't mean much, unless you are inflating tires.
  9. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    all air tools are rated to run at 90psi, the CFM at 90psi is most important if you ask me.
  10. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    for hobby use, I would say it's ok but like other people have said they are a lot louder than the oiled compressors. Phish had one and man was it loud.
    I just picked one up from princess. house of tools has a nice one on right now for $699.
    I would have bought it, if I would have seen it before I bought mine.
    http://www.houseoftools.com/content/houseoftoolscom/Flyers/Catalogue/page34.pdf
  11. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I really would be in that market for one, but my fatherinLaw is lending me his air comp, blast cabinet, solvent tank......... He had a compact vehicle lift too but I'll have to repair the main cylinder before I could use that.
    I'm not exactly sure what they are but for free they'll be FINE :D
  12. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Hey guys, thanks for the responses.
    I was out fighting a mouse infestation in my basement this weekend and I'm running behind on CK5...
    If by "Hobby" use, you mean occasional work on my truck, then that is exactly what I need.
    So far, I have done everything without a compressor on my truck.
    I'm in an un-heated Michigan garage, so it will get cold.
    I've wanted to get in the game for a while, but a 60gal with an oiled pump has remained out of my price range (assuming that I also need to buy tools to go with it).
    Right now I see the need to use impact tools, occasional grinding, a grease gun, possibly sand-blasting or spraying Primer.
    It says 9.9 cfm at 90 psi.
    With my budget, I have been considering buying a 30 gallon to get by for a while..... when this 60 popped up, it seemed like a good way to get in the game for a reasonable price.
    I know that they are loud (been around them before) and I know I may want to upgrade... but I need something to get me through for a few years until I can afford more.
    I've got to decide this week. I'll let you know what I do.
    -Ben
  13. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I would say go for it. 9.9cfm at 90psi is pretty reasonable, and for the price if its in good shape, which it looks to be. I'd get it. better to have loud air than NO air.
  14. cbbr
    Jul 17, 2004
    14,681
    Mine is loud as hell. I just wear earplugs and crank up the radio when I am going to be using it much.
  15. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    So what about this?
    Buy the $225 one for now. When the noise drives you nutzz get just the compressor cylinders, an oiled one. Could buy it new as replacement parts or maybe get a used one to rob the parts off of. Isn't the tank worth that anyway? I would guess it wouldn't be that hard to throw together.
  16. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    That's pretty funny.
    I was just wondering about that last night.....
    I wonder if anyone here has "re-powered" an air compressor before????
    That could be the perfect compromise.
    PS> I went ahead and offered $200 and we made the deal. I can't wait to have air tools at my disposal!
  17. 79BRUISER
    79BRUISER 1/2 ton status
    Jul 6, 2006
    739
    Indiana
    Id Buy It. I Built Mine Out Of An Old Cambell Hosfeld 5 Hp, 20 Gallon. Piggybacked It To A 20 Gallon Propane Tank I Got From A Buddy For 5$. Was Definately Noisy As Hell. I Moved It To The Shed Behind The Shop And Ran The Airline Thru The Wall, Wired Up A Switch In The Garage To Shut It Off. Noise Problem Solved. Cant Hardly Tell Its Runnin.
    What Voltage Is The One Your Lookin At. Check If Its 220v You Might Have To Run New Wiring If You Dont Have 220 Already. Adds To The Expense Cause Heavy Guage Cable Aint Cheap. A 220v Motor Is More Efficient Than A 110v Motor I Can See A Definite Difference In The Electrical Meter Spinning When The Compressor Kicks On. Mines 110v.
    As Far As Cfm Goes, More Is Deffinatly Better. Buy The Highest One You Can Afford. Its Gonna Suck If You Have To Constantly Wait For Pressure To Build Up, Especialy If Your Painting,running Grinders,cutoff Wheels,or Sanders. Low Cfm Will Also Wear Out Your Cutting Wheels, Grinder Wheels Faster, They Need A Certain Speed To Operated Efficiently.
    Sorry To Be So Long Winded, Hope This Helps
    Bruiser
  18. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I bought a 60 gallon upright from Home Depot husky brand (campbell hausfeld) for 449.00
  19. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I did it. For $200 I couldn't let it go.
    It's back home in Michigan now (I got it in Connecticut).
    We ran it in CT and it charged to 140 psi and held.
    Now I need to get my garage wired up, buy some air hose, get some air tools.......... :)
    -Ben
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    EBay is the place to get air tools. :deal:
