should i get loger drive shafts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by milspecjimmy, Sep 23, 2002.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i just put in a rough county 4 spring 4" lift. and now the truck measures a nasty 57" to the hood from the ground, i have 32's on it and i think i got a 6 inch lift in error. the front and rear drive shaft are out of the slip part of the yokes quite a bit, the front is not showing any splines, and the rear is not leaking. do you guys think i need to get longer ones?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd get the longer driveshafts made. I had new ones made when I put in my 6" lift. It wasn't too expencive, around $200.00 per shaft, but I went with all new everything and Spicer joints.
  3. Grim-Reaper
    7,385
    Atlanta
    Any drive shaft shop should be able to retube your shafts for about $50.
  4. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    I've heard the rough country 4 inch lift looks pretty high for a 4 incher but I think if it was there 6 you would have run out of brake line.
  5. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i bought the longer lines and put those on first so i really dont know.
  6. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    I have had two Rough Country 4" lifts and have two friends that have Rough Country lifts. Their lift is a tall 4" inch lift. I had an '87 SWB chevy with a Rough Country and 33s, and a buddy decided he wanted his to sit taller. So, he order a 4" lift from another company and put 35s on it. He came over and pulled up beside mine and mine was about a half inch taller. Needless to say, he wasn't very happy. So, yes it is a tall lift and I never lengthen my drive shafts on my SWB, but I think I'm going to on my Blazer.
