Should I go with a 3" body lift too??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jul 27, 2000.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Should I go with a 3\" body lift too??
    Since I have my gas tank out, I was scoping out the rear body bolts and thinking. I'm trying to decide if I should slap my body lift on my truck while the tank is out. It's just sitting in my room since I bought the lift and don't know what to do. I don't know how it would look with 9" lift and 35's. My friend is running 9" with 35's and it doesn't look that bad, but some people say he needs more tire. How hard is it to put a body lift on properly?? Is it worth my effort though?? Thanks
    Alex
    [​IMG]What me get stuck? NEVER!![​IMG]
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Re: Should I go with a 3\" body lift too??
    A body lift isn't that hard to install. Go to http:// espen.coloradok5.com and it will tell you what to do. I think you should run 38s instead of the 35s but its your decision.
    <font color=red>CHECK OUT MY SITE</font color=red>
    http://blazer-jimmy.coloradok5.com
  3. Re: Should I go with a 3\" body lift too??
    If you install the body lift there are other things you might have to do also,like longer steeing shaft maybe have to extend your fuel inlet hose from the body to the tank.Then there are all those linkages to adjust.
    But if you plan to run a biger tire latter then you should do it now.
    Hope this helps.
    IF IT AINT BIG IT AINT BAD!!!!!!
