Should I hold out for a 96-98 6.5?
Discussion in '1982-Present GM Diesel' started by 76_Cheyenne, Dec 10, 2003.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Im looking like crazy to find a new (used) truck. I want a 96-98 cause 96 is when they introduced the new cooling system. I talked to a GM tech and he said If im buying I should wait because the cooling upgrade is important. What do you guys think? I stop at 98 cause I cannot afford anything more. Its tough to find a good 96-98 3/4 ext. long box with a 6.5l and a 5spd. I found one, but its to far away. SHould I hold out for the upgraded cooling system?
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    The newer cooling system didn't come out until 97, and Yes it is worth saving up for. Join www.thedieselpage.com for detailed information.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Well depending on the truck it may be more economical to get a better deal on an older truck, and then add the new dual thermostat and water pump to that truck. There are kits for about 350 that have everything you need.
  4. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Well I found a 98, and it was well worth the wait! /forums/images/graemlins/thumb.gif
