Should I prime the pump?
Discussion in 'The Garage' started by Dallin, Dec 21, 2005.
  1. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    My 350 has about 25,000 miles on it. It's been sitting for the last 8 months while I finished my latest project. Do I need to prime the oil pump before I fire it up again?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I would. D/C the coil and crank it for a little bit. Not too long or you could hurt yer starter.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I would, but I'm pretty particular about my engines. I would change the oil first also.
  4. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    No flame intended Rico, but if your not gonna pull the dist. and spin her with a drill you might as well just light her up. She's gonna have pressure in about 2 seconds anyway.
  5. Dallin
    Feb 12, 2003
    135
    I was talking about pulling the distributor and priming the pump with a drill. It would sure be a lot easier to do it with the starter. I'll try that before I fire it up. Thanks
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Well my truck usually sits 2- 4 weeks before I fire 'er up. I usually just have the starter spin for about 5 seconds. Stuffs moving, but its moving slowly and oil gets everywhere. Pulling the distributor is best, and probly should be done if it has been sitting for that long. Do you use some sort of fuel stabalizer?? I would also check hoses and belts too.
  7. Dallin
    Feb 12, 2003
    135
    Everything is new fuel cell, fuel lines, carb even the radiator, hoses, pulleys, and belts. My only concern is priming the oil pump. I like the engine too much to take chances. I guess I should pull the distributor and do it right.
  8. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I have separate switches for ignition and fuel, plus a pushbutton for the starter. If my rig has been sitting a while, I'll crank until I see pressure on my gauge and then light the fire. Only takes a few seconds. Better to crank slowly a few revs without pressure than to fire it off instantly.
