Should I repolace my 6.2 diesel with a 454.
Discussion in '1982-Present GM Diesel' started by TK5, Sep 2, 2003.
  1. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I have an opportunity to purchase a 454 for $600. The engine is coming from a former drag racer that had pulled the engine after a couple passes on the strip. It has a standard steel crank that has never been turned and is great shape. The heads have been ported and polished and have a 3 angle valve job. The cam is a competition cams 292 with 526 lift and is also in good shape. Overall is the engine is good shape. The cylinders are in great shape with no ridge at the top. The only problem there is on 7 rods with pistons. he used the piston and rod in another 454. No intake or carbureter.
    I know that 454's cost quite a bit more if you can find a good one which this one is in great shape. Can I justify buying the 454 to replace a tired running 6.2 diesel. Should I purchase this engine to replace my 6.2? I know this a silly question but I had to ask because I have never had any dealings with big blocks, only small blocks.
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Lets see:
    454 5 mpg
    6.2 20+ mpg depending on ratio and driving habits
    454 gas expensive
    6.2 Diesel cheap
    454 more mods to make so it can be a gasser (torque converter, fuel lines, tank, electrical connections....etc...)
    6.2 Plug N play
    454 everyone has one
    6.2 rare breed of engine
    454 Pulling a trailer reqires you fill up at every station...oh wait..you have to even if you aren't pulling a trailer
    6.2 Fill up...um...sometime?
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1062598878OFFRDK5">
    Should he go with the 454 or the Diesel?
    <input type="radio" name="option" value="1" />454
    <input type="radio" name="option" value="2" />Diesel
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    A former drag engine you might be lucky to get 5 mpg, unless somthing is wrong with your 6.2 then you should keep the 6.2.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I wouldn't really trust a former drag engine, a coupl eof passes can seriously damage an engine that is why they pull them out after a coupl eof races.
    And as Tybee said, 5MPG is unrealistic with such an engine, a regular big block gets 5MPG.
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    thats PERFECT
    couldnt have said it better my self
    outher then i did change out a 6.2 for a 454 and i reggret it to this day it was only cause the diesel was on its way out and i didnt know much abnout em back then
    wont hapen again i assure you for the reasons allready posted but ya gotta learn how 2 work on em your self or the diesels specialist bills will kill al the saving's ya make from the gasser
    good luck 2 ya
    R
  6. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Thanks guys. I'm going to pass on the 454. I'll run the 6.2 tills it falls in to the grave. I just replaced all my fuel injectors with ones from Diesel Injection Service. It seems to be running better than it was. I gave $20.26 per injector plus mine as cores. I didn't think that was a bad deal but a whole lot cheaper than anyone in my are in Tennessee plus I got them in 2 days.
    Add to other problems, I have a guy that wants to trade me a '91 chevy SWB for my '83 blazer. Someting else to ponder!!! /forums/images/graemlins/confused.gif
    Thanks again.
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    That's take a while to happen. You think its dead and then it comes back to life!!! Just keep it out of lakes and it should be fine!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Thanks again.
    Actually I would have bought the 454 for $600, found someone to buy it for more and the profit could finance your engine's rebuild. /forums/images/graemlins/thumb.gif
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    First thing you are posting in the diesel forum, which is going to be very biased for the diesel( no offense to you diesel K5's but, yep, and thats fine with me.) I would get the 454 if you want some horsepower..wait guys.. If you want some higher rpm, faster horsepower. That 454 is probably pushing 500+ with the right intake and carb, much more than your 6.2. It would be more fun to drive because it would be fast as hell with the 454, sound awesome, and get the oohhs and ahhhs. It will be terrible on fuel economy. As far as towing the 454 will outpull that 6.2 anyday. Transmission and other drivetrain issues will have to be delt with. I would definantly go with the 454 if you can afford it otherwise I would build a hopped up 6.2, one that will blow some black smoke. /forums/images/graemlins/thumb.gif
    85K5 3/4ton, 14boltFF,10bolt, 9"lift,35"boggers, 16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
