Should I run a 160 degree thermostat?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Aug 2, 2004.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Went wheeling this weekend, well I was tacking my engine pretty high due to the sloppy mud. After a couple of holes I noticed my temp was around 230 and sometimes higher /forums/images/graemlins/yikes.gif. My stock thermostat is 190, will it screw up the computer if I run a 160 degree thermostat?
  2. J.R.
    J.R. Guest
    i run a 160 in my 89 k5 with no problems. /forums/images/graemlins/k5.gif
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Depends on if you have emissions regulations.
    Some of the emissions parts/computer require the temp be up to 195 for things to work properly. A 160 stat doesnt warm up the inside of the car very good during the winter when the heater is running either.
    Not sure the lower stat will help much with the 230 deg temp. Would think a supplement electric fan would be a better choice. You need to remove the heat from the radiator. The stock fan isnt running fast enough to get the required airflow while your wheeling.
    Just my thoughts /forums/images/graemlins/ears.gif
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Thoughts are appreciated /forums/images/graemlins/thumb.gif
    I've thought about a fan, especially since I no longer have a fan shroud. That will probably be my next bet, after I try the 160 degree thermostat. And emissions are visual only.
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Why dont you fix the problem instead of masking it with a different t-stat?
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I have to agree that a fan shroud will lower your temps considerably if not completly solve your problems. A lower t-stat won't help that much and you will still overheat if reving high and moving slow
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I agree...........no fan shroud, low speeds, high revs = overheat.
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I knew the fan shroud was the main culprit, but I accidently distroyed it when I put my body lift on. Where can I get a shroud that will work with my body lift?
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You'll have to get a stock one and modify it. I cut the bottom of mine off just enough to clear the fan. I have no overheating issues at all.
  10. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    You will be amazed at how much of a difference a fan shroud will make.
  11. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    My 89 1/2 ton burb with efi passed smog in california no problem with a 160 deg thermostat, and it sure made it alot easer for towing with that thing! also wheeling in the sand too.
  12. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    ...160 deg thermostat... wheeling in the sand too.
    Higher speeds + more airflow = lower temps
    IMHO:
    In low speed/high rev or at idle a higher temp t-stat will work better. This is because the water in the radiator is subjected to more cooling time while the thermostat is closed or trickleing. The more cooling time, the more consistant the temps will be with the t-stats target degree.
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Body lift = fan spacer /forums/images/graemlins/waytogo.gif
    I'm guessing the shroud is the problem... if you have 160* tstat running down the road the computer wont run right. I have a 195* tstat in my truck and it runs pretty well and rarely goes over 210 with the AC sitting in traffic /forums/images/graemlins/whistling.gif
  14. bigredk5blazer
    bigredk5blazer Registered Member
    Jul 11, 2004
    11
    Newark, Delaware
    With EFI you don't want to run a 160 t-stat without a PROM change. The truck may run fine, but will be running too rich all the time, because the ECU will still be feeding it warm up enrichment trying to see a temp of 185 or better. The lowest t-stat you can run is a 180 without problems. Given the cost of gas do you really want to be too rich?
    I agree with the consensus here. A lower t-stat is just a crutch. Fix what's really wrong. Another thought is the condition of the radiator. If it's clogged up with mud it won't radiate heat as effectively. A good pressure wash session at the local car wash can aleviate this problem. I've seen a lot of rigs run hot from this condition.
