Should I trade my Jimmy for a K20?
Discussion in 'The Garage' started by nad, Apr 12, 2007.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Okay, my Jimmy's motor is pretty much shot. It's an 87 Jimmy Sierra Classic 1/2 ton with a 4" lift and 35" tires. The paint looks good, but it has rust all along the bottom.
    A guy near here wants to trade me his 1984 K20 3/4 ton for it. The K20 has a 6" lift with 33's? for some reason. He said he did all the rust removal and it's now painted primer black. Also says it has a newer bed and doors.
    I like the topless factor with my Jimmy, plus the originality (you don't see a nice lifted clean Jimmy/K5 around here every day), but all in all, I think the K20 would be better for playing in and for hauling stuff...
    But the question is...Would you do it? Why or why not? Just want to get some opinions from someone else's point of view. Thanks guys.
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    yeah no rust and youve got a 14ff. if it runs then hell yeah.
  3. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    It doesn't look nearly as nice, but I guess form over function. Here's pictures of both my Jimmy and the K20.
    My Jimmy
    The K20
  4. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    still yeah. its probably got a 350 or better, and better gears for bigger tires, can always be painted if you really want to, just shoot it with 25 cans of flat black. then get new wheels and tires. definately.
  5. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    It's got a 305 bored 30 over. 350 turbo trans.
  6. Currank5
    Currank5 1/2 ton status
    Apr 4, 2006
    244
    South Dakota
    Well do you want a nice truck or a beater?
    You're Jimmy is nice. Looks like you just need to throw in a new motor and that would be a nice truck.
    The K20 looks kinda rough and would probably make a better wheeling rig. Wouldn't worry about bangin it up a bit. Might feel bad about dinging up that Jimmy as it looks like its in good shape.
  7. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Yes, I realize my Jimmy is in pretty good shape, but it only has 10 bolts on it, and I know if I put a motor in it, that will lead to bigger axles, bigger tires, bigger lift. Which I don't have time or money for.
    I don't know, it's a tough decision. I don't want people to think I traded my nice truck for a piece of crap. I'm gonna go look at it sometime this weekend and drive it and stuff to see how it looks/runs/drives.
    I could probably easily afford a 14BFF and D44 for my Jimmy, but I don't know if I'm mechanically inclined enough to swap them. It doesn't seem that hard, but then again, I didn't think lifting it would be hard either. That ended up taking 3 days because it took hours to grind each bolt off because they were rusted on.
    Any suggestions or opinions would be appreciated. Thanks guys.
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    swapping axles is not that hard of a chore. and if you've recently replaced the bolts then it will be even easier cause you shouldnt have to go through the task of grinding them off again. if you can do a lift then you can swap axles.
    as far as trading trucks, I say do it. if you plan on wheeling then its usually better to start off with a rig that doesnt look that good. plus its already got the lift and axles and a motor.
  9. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    i still say yeah.
  10. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    What do you want vs. what do you need?:rolleyes:
    Is this going to be a DD or trail rig?:confused:
    That Jimmy is sweet and I would not want to get rid of it. I think later on down the road you would regret getting rid of your current rig. How often do find a nice looking Blazer/Jimmy driving around.:(
    You may be able to find a beater for cheaper and then have both.
    My .02$ is to do the axle swap.;)
    *Edit*Just read your profile, do which ever one you can afford.
  11. Xtremegmc80
    Xtremegmc80 1/2 ton status Premium Member
    Mar 19, 2007
    1,976
    14
    NE PA
    Nice K20!
    :waytogo: trade it in! thats a nice k 20! the k5 is nice too, but the way u explain it sounds like k5 needs new engine, and some work. the k20 all it needs is a body work and some small work. so i would pick a k20 any day! do it!:k5: trade to:truck: then u will be a happy boy.. but yes.. k5 will be missed....
  12. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    well i dont know how theyre populated around you but theres four k5s in my neighborhood and four at school. i see them regularly, and rarely see anything other than a k10, thats pretty rare too. i had to sell my beloved 77 c10 because it couldnt get me to school. i sold it for $3000 and bought a k5 for $4000 which ran and had lift and tires, but well what im saying is get one that will get you to school and is more dependable than your 305 thats broke.
  13. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    As long as the drivetrain in the K20 is good, I'd do the swap. Invest in some more primer black and finish spraying the rest of the body. Hopefully you can run on those 33"s until you save up enough money for some 35"s.
  14. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    Why does he wana trade you something that runs good for somethign with a worn out motor????????????? Id keep the k5 and get a used 350 and a good shop manuel and doit your self
  15. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    He wants another project and he wants a nice driver. I will be using this for all sorts of stuff. Probably no extreme wheeling, mostly just camping trips, fishing trips, hauling stuff, and just summer fun. My Jimmy is nice, but the more I think about it, I want to do so much with it, like full rust repair, axle swap, bigger lift, etc. Rust repair alone overwhelms me, because in order to fix all the rust, I have to pretty much ruin the pretty paint job on it. And unless I have money coming out of my ears, I can't ever get it looking that good again.
    I am a college kid with a part time job barely making $200 a week. I don't have time or money for a full blown project, but I know I will regret getting rid of the nice looking Jimmy, and I especially know I will miss going topless and miss all the extra cargo space that is covered from the elements, as well as the rear seat.
    This truck has a disc brake conversion in the rear that needs to be finished, as well as some other small things that need to be finished. Also, couldn't I go bigger than 35's on that? He claims it's a 6" lift, but my 35's have the same clearance on my 4" lift that his 33's have on his "6" lift".
    I've always dreamed of having money and time to fix my Jimmy up really nice, but the more it sits, the more it rusts, and the more my neighbors get pissed. My choices are to either swap a motor in it and drive it like that until I have money to do axle swaps and whatever else, or to trade it for something else.
    I appreciate all your input guys, this is a tough decision for me. I'm going to look at the truck Sunday, so I will let you know what I think. Thanks again.
  16. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Probably going to look at it today. Anything in particular that I should look for? Things to sway away from? Thanks guys.
  17. Xtremegmc80
    Mar 19, 2007
    1,976
    14
    NE PA
    check behind the steering box and make sure the frame isnt cracked..
  18. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    And if it is? Don't trade? I'm pretty sure my frame is cracking on the Jimmy, if it's not badly cracked already. I plan on putting a weld on brace and a bolt on brace on top of that. Thanks for reminding me to check that though.
  19. Xtremegmc80
    Mar 19, 2007
    1,976
    14
    NE PA
    u can still trade and do the weld on brace. just thought id bring it up cause alot of people forget to check that spot.. my old truck was badly cracked.. ended up doin alot of welding. result was good.. my 80 gmc has no crack.. soon will make it stouter. just check around. make sure the frame is good. take it for a ride if its road legal.. just make sure it doesnt clunk or anything like gearing is bad. some time if it clunks check the u joint.. they are easy n inepensive to fix. if ur 4 wd works. make sure the k 20 4 wd works too.. im sure there are a few other things i forget. so just have a look around. make sure the frame isnt rottened out. stuff like that. i cant really think of anything else.. good luck!:smile1:
  20. Xtremegmc80
    Mar 19, 2007
    1,976
    14
    NE PA
    updates?? traded or not?
