Should I trust a radiator leak stopper?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Apr 25, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I have a leak in my radiaotr on the bottom passenger side corner and I'm a little worried about. I saw this radiator leak stopper stuff you put into the radiator but Im not sure if its a good idea or not. Would anyone recomend this type of product? Seems like if it could stop a leak it could clug the radiator? any suggestions? Thanks
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Short term - yes. Long term, no. Go to www.radiator.com - I got a 4 core new radiator (Modine) for $162 delivered to my door next day air. It's cheaper now with a CK5 discount too..........
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Only long enough to get home and/or get it to a repair shop.
    Even at that, I've heard them accused of stopping up block/head passages and other really bad things. I've had no experience with that so I can't say for sure.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I used that stuff in my first car (1986 Pontiac 6000 STE) and it stopped the radiator leak, but it also caused the thermostat to seize and stay closed...Needless to say, there was a nice big mess in the parking lot when my radiator cap blew off and coolant was spewing out like Old Faithful...haven't and won't use it after that event...
    Chris
  5. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    The passages in a heater core are smaller than those of the radiator. I wouldnt use it for fear of clogging the heater core.
  6. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I used it in a car that I had wrecked and made a nice imprint of the fan in the radiator. It stopped the leak and the car ran fine for the next 3 years. Results may vary.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Pinch the offending tubes off.
  8. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    radiator leak stopper is the DEVIL. It will only make you pay in the long run and the leak will just come back. I have seen this used in many vehicles. It has a habit of clogging heater cores and sometimes the radiator. If you can aviod it, don't use it. It is meant to close up small holes or openning, which is exactly what your heater core/radiator is designed around.
    My two cents,
    Mike
  9. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Its not a tube, its the actual radiator thats leaking. I guess i'll take a better look at it and If its unfixible I guess ill use my CK5 discount to buy a new one. Thanks for the input, ill stay away from the leak stopper.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Use JB Weld if it's a tank.
  11. dyeager535
    26,982
    191
    A PO of my sisters car used some sort of stop leak to try and cure the heater core leak (worked for awhile) but she couldn't figure out where the coolant kept going right after she bought it.
    Turns out the stop leak stuff made its way through the system and some of it ended up in the overflow tank. Coolant would flow into the tank when the car was shut off, but the stop leak stuff acted as a one way valve, so the coolant reservoir filled up, and would only overflow after the car heated up after shutdown...just enough time to walk away before the coolant started dripping on the ground.
    New radiators really aren't that pricey, I'd seriously consider one. Unless the one you have was new but accidentally got a hole poked in it, more than likely its much less effective at cooling than it could be, which is why it rotted out...its old and corroded internally.
  12. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I just replaced my 90's radiator with a High Efficiency Aluminum Core made by Performance Radiator, Part #62-84. My radiator sponsor gave me it at his cost of $105, I don't know what the retail cost is though. I had to do some minor trimming of the rubber mounting pads and the fan shroud, only because it is thicker than the original. Other than that it fit perfectly. All hoses and Trany Cooler lines lined up. It has a HD Trany Cooler in it as well.
  13. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    3 words for you "DONT USE IT" I used it on my old Camaro and it did stop the leak but it also clogged the radiator bad, I had to buy a new one.
