Should I Try 38/13/16 on a D44 front ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Resurrection_Joe, Mar 8, 2002.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I want to change to a bead retaining rim and have some 16x8's kcikin around, but I cant decide between 36/13/16 or 38/13/16 TSL Bias. Any thoughts?
    BTW - I have 4.10's and a mild motor. I run medium trails and shallow mud. Other specs are in my sig.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    with 4:10's i would go with the 36's i have 4:10's and the 38x13x16's and i realy wish i had atleast 4:56's if not 4:88's oh and that is with a dana 60 with your 44 i would stay with the 36's if you wheel hard at all
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I have 38's on 3/4 ton diffs with 4.10's.It's alright with the present TH350 trans,but I'm going to an SM465 4 sped manaul soon.It should be nicer with the lower granny gear.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the sm465 np205 combo and still wish i had 4:88's instead of 4:10's /forums/images/icons/frown.gif
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I'd get the 36s, unless you plan on re-gearing. If you had 4.56s, either tire would be within your range.
    J
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    agree'd
    i had 38.5 and 4.10 d44 14ff
    i definitely liked the switch to 4.88 except for the hiway rpm is a little high for my taste but others like the 2600rpm cruising
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i dont like that high of rpm but i plan on my next set of tires to be either 39.5-42's so 4:88's would be best for me /forums/images/icons/smile.gif
