Should i use D for going up hills?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Feb 19, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    Should i used D instead of OD for going up hills?Why or wny not.Thanks for any help.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm assuming you're referring to driving on pavement. On a steep hill, you'll probably be into the pedal quite a bit. This will cause you tranny to drop to D, and it won't go back into OD until you've reached more level ground and back off on the throttle.
    FWIW, on long uphill climbs(we have a few around here;)), I manually gear down to D and don't re-engage OD until the end of the climb. Staying in D keeps you in the power band, anyways. That's where you want to be going up a hill.
  3. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    I agree with the previous post..
    But would like to add
    Yes if its HUNTING..that is, if it is shifting up and down over a short period of time..like a combination of slight grade and maby wind, or rolling hills, or varing grade on a hill
    That will make it hot, and wear the clutches
    Othewise let the trans decide.. /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  4. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    When im on the freeway i hear a humming noise is that the overdrive. The only time i hear the humming is when im at a constant speed over 50mph.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i always down shift when going over hills. more gearing for tires already struggling to get a 3 ton truck to a summit can't be a bad thing.
