Should i use Gasket sealant on a Fel-Pro tranny pan gasket? dumb question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Mar 30, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    kinda stupid questoin but im sick of working on this person's truck and i want it to be over with hehe, just making sure, thx
  2. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    please help, its getting dark outside, and i want to get it outa my driveway, thanks......
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't EVER put ANYTHING on a tranny pan gasket.
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    you can use a little grease to help the gesket stay in place but dont use any gasket sealer
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    rtv+transmission=DEAD TRANNY
    grant
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    josh dont put any on it will be fine without it /forums/images/icons/smile.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oh and dont over tighten them
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    A little grease can help it stick...I think that was already suggested. Also, easy on the tightess. Tighten bolts in a cross pattern to avoid bending the pan.
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    well damn, i went outside after awhile ( i got impatient heh ;[ and put gasket sealant on it, oh well, it wasnt that silicone stuff, it was that brown crap, and i let it dry for a few hours, damn you think i should get a new gasket and redo it? i think i remember doing it to my old tranny awhile ago and nothing bad happend,
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    as long as you didnt get any inside the pane edge you should be ok
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd pull it off and re-do it.
  12. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Why would putting a little gasket sealer on the tranny gasket to hold it is place cause transmision problems?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just like silicone can clog oil pump pickups, it can plug up transmission pickups.
    I hate silicone period, but in some places you just have to use it. A tranny gasket isn't one of them.
    I am simply offering my opinion. I'd take the pan down and re-do it.
  14. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If you used the Perma-tex #2 brown goo it will be fine so long as you just brushed a light coat on it.
    I use High tac on gasgets, the spay kind.
  15. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    Transmission gaskets dont require anything now days. Just put the gasket on there and tighten up the bolts till you see the gasket start to smash out. Transmission oil will eat through silicon after awile and start to leak and can plug your tranny.
  16. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    yeah, what everyone else said.
  17. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    Not a big deal. Let it be for future reference.
  18. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    do not use any sealent ,
    not only will the tranny fluid eat through
    the sealent , but you also take a chance on getting some
    of it floating around in your tranny and wasting it.
    i remember the fist time i used sealent along with the gasket ,
    and i drove thr miles , went and watched my son play ball ,
    then went back to a huge puddle under my truck.
  19. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Well what do you use to get the gasket stay on the pan? It was impossible before I put the gasket stuff on to hold it. Should I redo it with grease? any other suggestions?
  20. dyeager535
    26,979
    Don't worry about it unless it leaks. Period the end. I've heard it both ways as well. In a perfect world, no gasket or sealant would be needed, the surfaces would be perfectly smooth, and no fluid would leak with a metal to metal finish. It's not a perfect world, and stuff leaks. If you can get it to leak without silicone or sealant, great! If you can't, use the stuff, just be careful of how much and where you use it.
    I've tried both ways on all the trannies I've worked on, with silicone, I typically have no leaks, without, sometimes I do. I use it on the diff cover as well, and same as the tranny pan, you'll hear tons of different ways that are "right". What they are, are ways that have worked for people.
