should i weld it?
Discussion in 'The Garage' started by basing110, Oct 22, 2006.
  1. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    298
    san diego
    well i have the gov bomb in the back of my 14 bolt .. im running 44" boggers ... now the question is should i get an open carrier and buy a detroit locker so i can make better turns?? or should i just weld that sum o bitch up? also anyone have a guide or pics on how they welded up a gov bomb?
  2. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Open carrier and Detroit.
    I had a gov lock too and I think I paid about 50 Canadian for the open carrier and sold the Gov bomb for about the same.
  3. raymos
    raymos Who?
    Jul 6, 2006
    479
    8
    NOR CAL
    yep i got a open carrier for 4.65 and lower for 60 on e bay. sure beats 3 hundred somthing they are asking new.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i love my detroit in my 14b :)
  5. basing110
    Aug 4, 2005
    298
    san diego
    is the detroit that much of an advantage for trails? im trying to weigh the cost of carrier and locker ,maybe ill just weld it up till i can afford to finish the rear axle
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    54
    Powell, Wy
  7. goldwing2000
    goldwing2000 Guest
    Welding is the best thing you can do to a gov-bomb.
    Then you can run it until you save up the money for an open with a detroit. :D
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I say weld it. I welded mine on my dd. I love it and if it dont turn sharp enough just tap the throttle and itll come around.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If your main concern is just trail performance, save the money and just weld it. In a rear diff on a trail, I doubt you would really be able to tell the difference in regards to turning. Several guys in our club, including myself, have been running welded rear diffs for years now and have never had any issues on the trail.
  10. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    weld it and put the money into a d60 for the front if you don't have one yet.
  11. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I love my detroit. you could always get a spool.
  12. basing110
    Aug 4, 2005
    298
    san diego
    so the farthest ive gotten on a tear down on my carrier was removing the gears when i swapped them .. lol so how do you guys go about splitting teh carrier?
  13. MNorby
    Dec 10, 2001
    6,127
    54
    Powell, Wy
    there is a tech article about installing a detroit. Follow that but instead of pulling the spiders out tack weld them while they sit in the one half of carrier then flip them into the other half of carrier and tack that side (That way the fit back in after you finish welding) then pull them out and weld the holy living piss out of them, then weld some more and repeat instructions in reverse order to re-install.
  14. basing110
    Aug 4, 2005
    298
    san diego
    so i read up on the detroit install and it looks like on my gov bomb after i remove the bolts holding the ring gear on then it just pulls apart by itself?
  15. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    No, mine stays locked most of the time, think about how many times you're trying to make tight turns on the trail when you're NOT on the gas (even a little bit). It doesn't happen very often.
  16. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you can not put a detroit in a housing that was a gov-lock. you have tio have an open carrier.
  17. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    related question...
    are there any issues with all that welding/heat of the axles not fitting back into the side gears? i was thinkin about a spool, but i may just get my gov lock welded.
  18. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    as long as you use the carrier to start welding everything together, there should not be any problem about fitting anything back together. be sure to clean out the slag from the side gears before installing the carrier to the housing.
  19. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    ^ What he said :)
    Just don't weld the front :doah:
  20. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I did it backwards. I have aboot $350 in my open carrier and detroit in my 14FF. I however do run a welded front as I could not afford a Detroit for my 60 at this time. It def drives different but I did not have any problems with it last weekend. I do have a hydro setup to put on I just need to make one hole and do some welding:o . Like was said if you do not drive it on the road alot I would weld it up cause my detroit is almost never unlocked even on corners:D
    Ira
