Should I weld my differentials??
Discussion in 'The Garage' started by chaka454, Nov 20, 2002.
  1. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    I have a 93 Toyota pick up with a 4" suspension lift, 3" body lift, and riding on 35 super swampers, I dont know what gears I have but the truck runs pretty good, my problem is that I dont have posi, I have a friend that's a mechanic and he suggested that I weld my differentials, he has a scout that he welded his differentials and they are running pretty strong, he suggested I do the same thing but before I welded them I wanted some advice from the best (you guys) any info on this would really help me if it's a good idea I want to weld them this weekend, thanks guys.
  2. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Searched using "Weld Differential gears" using the "and" function and came up with a lot of hits. This one might help
    THREAD
    Although, I don't know that you'll get much Toyota input.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If its your daily driver I wouldnt.
    A buddy of mine with a Toy that has a welded rear goes through a pair of rear tires every 4 to 5 months. /forums/images/graemlins/grin.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There are issues that come up with weding Toy diffs, something to do with the fact that the gears in a Toy diff contact each other in a slightly different way than in most diffs. Can't tell you much more other than do some serious research before you do it.</font color>
  5. chaka454
    Nov 13, 2001
    199
    California
    I will do my homework before I do it thanks guys, I read the threads too and now I'm thinking about it, thanks for the info guys.
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    welding your rear diff will be alright, but dont weld the front too hard on steering joints and shafts.
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    like everyone else would say i personally wouldnt weld them if it is your dailey driver, yull wear out your tires faster, and yud probly be better off getting an auburn locker, or somthing, i should of when i had the 12 bolt off my truck in the shop but 300$ plus 250$ for labor was alot at the time, and a open diff is probly more reliable then an auburn, of corse then i could be wrong. /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> First off, you're lucky that you didn't get the Auburn. I've had experiences with only 2 of them, but both broke in less than a year. Mine broke with less than 3000 miles on it. Second, Auburn doesn't make a locker, it's a limited slip. They make two versions, the regular one and the Pro, which just has a tighter bias. </font color>
