should my 1985 305 cid have an Oxygen sensor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Oct 13, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I dont have the truck near me now but will a 1985 have an o2 sensor? If so I would assume it is located on my header somewhere.
  2. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    look on the drivers side exhaust manifold, near where it mates up to the pipe....I have an 87 TBI engine, so not quite the same I know....
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my dads 85 k5 blazer didn't have one. i guess the cali emisions(sp) could have one /forums/images/graemlins/dunno.gif
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    no, because it isnt fuel injected, it would be pointless to have an O2 sensor, because the carb cant adjust to whatever the O2 is reading.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    It will for surely have one if it is equipped with the california standard emmissions equipment. It will have the wonderfull computer controlled carb and distributer setup.
  6. mahorney
    mahorney Registered Member
    Jun 10, 2004
    28
    Highlands Ranch, CO
    It don't believe it does. I took some parts off a stock 85 truck with 305 that didn't have one. I bought a set of edelbrock emmissions legal headers and they have the oxygen sensor port on the driver's side. Had to plug hole.
  7. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    My 85 had the "High Altitude Emissions" package with a knock sensor, but no O2 sensor.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Correct, if it has a feedback carb, it has an O2S!
  9. dyeager535
    26,982
    191
    As was stated, with a feedback carb (CCC system) it WILL have an O2 sensor. Apparently not a knock sensor. This apparently applies ONLY to certain models destined for CA originally.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    80-up is when the system existed, most of them all had O2 and MAP sensors, etc, this system was used on lighter max load(GVWR) rated cars and trucks under 8000 or 8001 lbs,
    heavier max load rated vehicles had a TCS system, a metal relay deal on driver side valve cover, this was for heavier GVW vehicles, mostly with 4 speed but not limited to that
  11. dyeager535
    26,982
    191
    Not quite. CA only emissions trucks were either CCC, or not. CCC uses both O2 and MAP, no exceptions. If it doesn't have those, it doesn't have a "feedback" carb, and is not CCC.
    One interesting difference between CCC cars and trucks is that *apparently* the trucks didn't use a knock sensor in all CCC setups (or perhaps any) along with Oldsmobile engines which also didn't use a knock sensor until about 1987, while all Chevy car applications did.
    CCC was used on ALL carbed GM *cars* starting in 1981 and ending in 1990. Started in 1980 IIRC only on Cadillacs, at best a VERY limited number of vehicles, not 100% as in 1981.
  12. J.R.
    J.R. Guest
    mine had the knock sensor but no O2...
  13. dyeager535
    26,982
    191
    Then it's ESC, not CCC.
