Should my 205 do this?
Discussion in 'The Garage' started by divorced, Dec 2, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I can move the rear driveshaft up and down; it moves the yoke and output shaft of the t-case. It moves quite a bit and I think that may be why my new seal leaks. I can also move it in and out of the t-case. Is that common for these or does it need rebuilt?
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Fixed or slip yoke style?
  3. divorced
    Jul 20, 2004
    5,115
    Ya, I guess that's some important info that I forgot. It has 3 fixed yokes; 1974 Dodge divorced case. The rear output is the one that move a lot.
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    My best guess is you've either got a loose yoke nut, or a fried output bearing. The unit can have a little play in and out, but it shouldn't move up and down.
  5. divorced
    Jul 20, 2004
    5,115
    It may be the bearing because I can see the threaded end of the shaft move up and down also. It also make somes noise when driving down the highway. It hard to explain what it sounds like, but if I let off the throttle it will quit until it gets some back force from the enigine compression, then it starts again.
    Is the bearing difficult to replace?
  6. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    That is not good. Call ORD and get the new bearing and info on anything else that you will need. /forums/images/graemlins/thumb.gif
  7. divorced
    Jul 20, 2004
    5,115
    Ok, I'll give them a call. Thanks /forums/images/graemlins/waytogo.gif.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    they move around a fair bit
    the shafts are 30 years old, man.
    big sloppy roller bearings with a bunch of loose rollers on the snout, not precision
  9. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    mine moves. and it makes noise. its gear driven.
    and its divorced. i tried to tighten the nut SEVERAL times. i finally brought it to a tranny guy who miced it and said it was normal
  10. divorced
    Jul 20, 2004
    5,115
    Maybe I'll just let it be and continue to run the snot out of it then. /forums/images/graemlins/peace.gif
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Pull the bearing and find a bearing shop (more than an auto parts store) to see if it is bad. I thought I had a bad bearing in my 203 and upon inspection of a new on it acted just as sloppy.
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    My Rockwell t-case did that...turns out about 1/2 the balls in the bearing had jumped ship /forums/images/graemlins/eek.gif
