should qjets have a spring with the choke?
Discussion in 'The Garage' started by wazzabie, Aug 27, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    I'm looking at several chokes all on the same type of carb 4BB qjets from 77-78 divoriced choke. I find that some have springs as in this picture
    http://www.carburetor.ca/HTML/gallery/QJets/V247/images/rfq17057213.JPG
    and others in my collection have no spring. Did all come with springs or were the springs removed?
  2. dyeager535
    26,980
    I don't think they all had the spring. I recall seeing them both ways.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    im not suire which spring you are referring too
    the choke one ?
    the spring for thast type of carb in that pic is mounted on the iontake manifold and a rod runs up from that to the linkage on that carb righ there in thast pic is the lever with slot hole in it for the top of the rod end the slot if vertical cut you cant miss it, it is for the rod from intake mounted spring, all of these carbs had one and the rod
    these were used on cars ands trucks both, mainly all mid 70s like 73-78
    i dont like them at all, i like to put on electric choke ones in place of these, even thoguh you can buy this type of spring for these for cheap at parts store, botg warner boxed ones, auto zone and such, i even have one laying around, unused brand new, i dont use these carbs i have a couple laying around im trying to get rid of,
    good luck
  4. dyeager535
    26,980
    I *think* he's talking about the one that is on the rod coming out of the diaphram in the picture.
  5. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Yes .. I have several 17058213 carbs for a 78 chev truck. I find that some have the spring coming out of the diaphram and others don't. I'm not sure if these had the spring original since I got the carbs all ready pulled-off.
