shoulder belt in '72 Blazer
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bdkmiller, Aug 11, 2002.
  1. bdkmiller
    bdkmiller Registered Member
    Jul 31, 2002
    42
    NH
    shoulder belt in \'72 Blazer
    Has anyone installed a shoulder belt in a 1st gen Blazer? I noticed plugs on my single wall hard top & wodered if they were for optional shoulder belts.
    Thanks in Advance,
    Brian in NH
  2. ta70cst
    ta70cst Registered Member
    Nov 14, 2001
    28
    Colorado
    Re: shoulder belt in \'72 Blazer
    I just had them put in. Yes, those holes were drilled at the factory for an optional 3 piece. I had a guy in denver install mine and it works great and is a bit safer.
    /forums/images/icons/smile.gif
  3. NuBombs72K5
    NuBombs72K5 1/2 ton status
    Jan 21, 2001
    145
    Georgia
    What were the belts out of? I've heard of guys using the belts out of an s-10, but I wonder if any others will work.
  4. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I've been looking around and the best choices that I've found are from a late 90's tahoe or suburban. These (i think) could be bolted up to the existing holes with a little trimming of the plastic fairing. The other option (my choise) would be belts from a jeep wrangler. They are a self contained unit that could be bolted to the forward bed post.
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I'm Looking around also for the same. If You guys come up with something, that fit's somewhat close, please post it!
    /forums/images/icons/grin.gif
  6. 71Blazer
    71Blazer Registered Member
    Dec 17, 2001
    24
    Coupeville, WA
    Hard top hoist
    I had a brainstorm about those same threaded holes at the four corners. Could they be drilled through and fitted with the right insert to make external lift points for hoisting the top off? Just an idea, no prototypes yet /forums/images/icons/cool.gif
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Re: Hard top hoist
    good idea. i would trust it to hold up the top before i would trust it to hold me in a wreck. something about the fiberglass.
    nathan
