show me yer hydroassist and Highsteer pics
Discussion in 'The Garage' started by Seventy4Blazer, Apr 10, 2004.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Im looking for hydro assist and highsteer combo only please.
    more pics the better. a little info on the type of ram system you have and the highsteer arms you are running. D60 stuff is best.
    Grant
  2. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    what is TTT?
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    TTT means Two Tiny Titties. /forums/images/graemlins/waytogo.gif
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    what is TTT?
    to the top.
    im still looking for pics.
    Grant
  6. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    In these pics it's obviously not done, but I have it complete and running now. I haven't put the big tires on yet so i am still rolling the small donuts but boy does it turn nicely. I know it's a lot of red but it looked good when it wasn't all together. Now that there is so much red all in one spot, I don't really care for it. But Oh well, it'll get dirty in no time. /forums/images/graemlins/woot.gif
    Ask away at any questions.
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    What happens if you hook up the lines backwards? Tell us /forums/images/graemlins/whistling.gifEsteban.
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Hmm, thats a nice diff cover protector ram mounty thingy... /forums/images/graemlins/whistling.gif
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    Jason, did you make that dif cover ram mounty thingy?
    question/observation why not a plate going from center to left and or right of the ring gear protector? the ram puts a lot more side to side force on the setup as shown. i dont know the thickness of that cover or anything but i think it would be a little more sturdy if a LOT of force was put on the tires from the ram anyway.
    Estiban, nice setup you have. thanks. also who made your engine x-member? looks sleek and smooth.
    i want one..
    grant
  10. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I got the high steer on. Have to put the diff armor on still and figure out were the ram needs to mount. Should get that done on monday. I'll try to get some up to date pictures.
    BTY PM me your email addresses
  11. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yes I did and it is 3/8". It's not going to go anywhere, especially with where he mounted the ram. I usually make those, then plate them in completely to make my covers that I sell but he wanted one asap to mount the ram to and we decided on that style.
    He made the engine crossmember, but I helped, well, at least my plasma cutter helped /forums/images/graemlins/rotfl.gif
  12. Esteban86K5
    3,712
    Bakersfield, CA
    Yup, Jason made that dif cover ram mounty thingy. And i don't see it going ANYWHERE. It's pretty damn thick and like Jason mentioned, I put the ram mount high enough that it shouldn't move.
    The engine crossmember I made out of some 2x8 rectangular tubeing that I had laying around. I had a post about it a while back. Look in the link on my sig and you can see all the pics on it.
    And YES if you hook the lines up incorrectly, you will blow a seal on the box and have PS fluid all over you gargae floor and walls. So don't DO IT!!! /forums/images/graemlins/doah.gif
  13. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    ORD high steer setup and WTO Redneck Ram.
    The box welded to the top of the axle tube is 2"x3" capped and I welded on the tabs Matt sends with the rams.
    Yes that is my vent hose hanging down. I need to put and 90 degree fitting in the diff housing to hook up the hose to avoid the bolt through the end of the ram. I have had no trouble with this setup so far and am extremely pleased. I spent a lot of money last year upgrading my steering (along with a Borgeson steering shaft), but it was worth it.
