Show me your cb antenna's
Discussion in 'The Garage' started by coptezr, Sep 3, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    Im look for a spot to put mine i got my DIY rear bumper on but i really dont want to put them there. :D
    thanks
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    mines on the roof of the cab, jus behind my sunroof. ill try to get a pic up. its about a 4' antenna, only thing is that it hits trees and such, but its no big deal. the higher up, the better the reception :D
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Mine is apparently similar to muddybuddy's, I had one on each of my light bar on the roof. One runs CB other runs stereo. Great reception for fm radio by the way. Only problem is I had to remove after my trucks last growing spert (hits the roof of my garage and carport). :crazy:
  4. coptezr
    Jan 13, 2005
    342
    how did you mount it on your lightbar
  5. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Most light bars have extra holes due to all the differant styles of lights there are, so I used the two outer holes with insulating washers to keep it from grounding out. Oh yes since I used fiberglass antenna's I had to put a small antenna spring on to keep from breaking them off on tree limbs and stuff.
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I bought the 90* bracket and mounted it to my rear bumper. 10' whip, big spring, and a Galaxy DX88. It would talk about 20 miles barefoot.
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    not a close up but this is where my antenna was when i bought the truck and its served its purpose ever since. ya it catches some trees but never done any damage.
  8. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    The previous owner of my truck had something on the roof, but im not sure what. There is a hole and a ton of scratches right at the back of the roof. Im going to be using that hole for a cb antenna. A) Because I want to, and B) because i dont want it to rust out.
  9. coptezr
    Jan 13, 2005
    342
    Thats exactly where i want mine but i dont know if i should get a steel whip or a fiberglass one. i like that way your fiberglass whip looks like.
  10. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
  11. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Funny you mention this ... just doing this today. You got a roll bar?
    I was thinking about welding a little plate on my cage somewhere, but I couldn't decide where... so I made a removable/adjustable mount for the antenna, will go anywhere on the cage now.
    Piece of plate with four holes for U-bolts to loop around the cage, and one big hole for the antenna... voila. I didn't like how stiff the antenna was so I put a spring in it (mmm, flexy antenna! :haha:) ... when I trailer the truck I'm still gonna loosen the plate and flip it down horizontal. No reason to stress the spring.
    I also notice all y'all seem to have fiberglass whips, rather than steel. Is that a rustbelt thing?
    I'll be interested to see how my giant steel whip fares (it's a quarter-wave, i.e. eight and a half feet) but worst case I'll tie it down like the military CUCV's.
    -- A
  12. coptezr
    Jan 13, 2005
    342
    you have any close ups? :D
  13. coptezr
    Jan 13, 2005
    342
    thats pretty sweet but no i dont have one.
  14. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    thats the best ive got. All it is, is the mounting bracket i got the antenna with, and i reinforced it a little and then used 3 self tapping screws.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The light bar is a great place too mount a CB antenna. I recomend a ground strap though. I have ran 102" Stainless steel whip on a heavy duty spring (pot belly) mounted on light bars. Works very well. Preformance has always been my main goal with the 2-way radio equipment.
  16. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    Ground is good..
    I agree--the antenna in the first picture with the u-bolts on the pipe for a mount should definately be grounded better with a strap or wire..only certain fiberglass marine antennas can be used with no "ground plane"--if the ground is poor on a regular antenna,a high SWR reading will result,and it could damage output transistors in the CB..and fiberglass K5 roofs aren't grounded,dont forget.. :crazy:
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Right on the top of the cage just in front of the spare-
    It's a Firestick I think. And as far as I know, cb attennas need to be mounted as high as possible with as close to 360* clearance as possible for best results. That means mounting it on the roof is the best place.
  18. coptezr
    Jan 13, 2005
    342
    I really like how yours is mounted i wonder how 2 of them will look.
  19. dremu
    Feb 27, 2000
    15,954
    445
    Well, this is one of the down sides to having no roof =)) The only flat metal surface I have is the hood, and I don't want to mount the antenna to that!
    So you think a a nice ground strap, from, say, the plate to something solid? (:haha: finding something solid and non-Bondo on this truck may be tough!)
    -- A
  20. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I mounted a 9' whip to the rear corner of my bed on the inside......works great and looks good :bow:
