show me your flaps
Discussion in 'The Garage' started by BIG*RED, Oct 13, 2005.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i got pulled over by the local pd, and he told me that i needed to get mud flaps on the back of my k5...not sure if i really need them or if he was just having a bad day. but eaither way i figured i would look into it..
    so those of you running mud flaps..how do you have them mounted, where did you get them? i looked around at parts stores and only found those small cheepy ones...and those are not gonna work..
    oh an dpost up pics of your mud flaps..lets see what size you got and how you have them mounted
  2. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I have the big dumb semi style flaps to stay legal. Mounted them to a piece
    of 1" square tubing, then took a piece of 1.25 " square tubing about 2" long
    and welded it to a flat plate and drilled 2 holes in it that bolted to the frame.
    the tubing that holds the flap slides into the one on the frame and I use a pin
    to keep them in.
    I have to remember to take them off, forgot one day and backed over one... :doah:
    edit: I think i paid $8.00 or so for one of the flaps, other one I found on the side of the road. The patterns don't match, but so what...
  3. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    is it illegal not to have them on...how tall does the truck have to be for it to be legal with out them...cause i really don't like mud flaps
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Join the club, brother. I hope we never have to worry about that here. :doah:
  5. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    here in alaska the "anti spray device" must extend down to 14" off the ground.nomatter how tall it is
  6. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    My friend did similiar to what thor did. He built a "fake-bumper" that mounts into the hitch reciever. It's 16gauge steel, formed into a rectangle and capped off. it also mounts his mud flaps.
    It keeps his bumper height legal and more cops don't look twice then, and also has mud flaps that are easily taken off before wheeling.
    His next plan was to even add some brake lights that plug into the trailer wiring. Totally optional though. But if you have issues with your lights in your state, it may be better for you.
    I'll try to dig up some pictures of it.
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    We had the same problem in the bush with the trailer mud flaps on the log trailers , backing up and removing them :doah:
    So now we just put a small hole in the bottom of the flap and use a heavy bungee cord to hold them up , out of the way (just fold them up and hold them with b.c. until there is no more problems)
    Looks like this would work on your rig for those times when you did not want to remove them for some mild wheeling
    Once up to the rockers in goo :dunno:
    BTW that is a fun looking rig :wink1:
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    my wife told me that the truck was going to be legal once it went on the road. Well we put it on the road and I had to get mudflaps... well I bought them, put them on and said I didnt like them.. she said oh well it must be legal... however once she walked ouside to look
    at it she was like...
    HELL NO We will pay the fine every time... :haha: :bow:
    so when I went through inspection... the guy said they had to be pushed out 2" more on each side
    anyhow they are now on my garage floor being used as floor mats...
    I am going to make quick disconnects.. a guy showed me how he did his.. used round threaded rod.. forget size.. but there is a hole in the frame and also a hole in the wheel well on the bed... I may loose ya on this but will try not to...
    take the rod say for the drivers side.... put a nut on 1 side say 2" in... you can put the rod into the frame on the other side... then put a nut on the bed side where the other nut was... then thighten them together... this makes a mounting bar that can be removed... next mount your flaps to them with u bolts... hardware stores sell small ones... so like this...
    --|-------------------------------O|O
    I know bad example... but on left | is the frame.. on the other side is nut, bed hole, nut
  9. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    if the cop knows that your k5 is an SUV then you dont need flaps in cali. but a pick-up does need the flaps. SUV's dont need flaps. i got pulled over once and argued with the cop and he called it in and found out that i was right. he was kinda pissed.
  10. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    haha alright...no mudflaps for me
  11. sparkyincali
    sparkyincali Registered Member
    Sep 30, 2005
    6
    Sf Bay Area
    hey Psychoticdeadguy do you happen to know the part of the vehicle code that states this I live in the bay area too and dont wanna run flaps when I lift and would love to have a copy of the section of the code in my k5 in case I get pulled over
  12. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    In cali if the tires are more than a 1/2 inch past the fender they require mud flaps......................... :doah:
  13. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    Mud flaps suck I will never put flaps on anything! Arizona classifies suv's as a wagon and they do not require flaps. Trucks that are lifted do and 1 tons do also which makes no sense. I got pulled over in my lowered dually for flaps go figure that one out.
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Had em... hated em... I don't drive it on the street so I threw them away :)
    Here's a pic of the truck with the 12" lift and the flaps.
