Shower drain into drywell
Discussion in 'The Lounge' started by newyorkin, Dec 24, 2004.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I was just thinking, as I flushed and heard the shower drain gurgle, is it ok to run the shower drain out to a drywell?
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Whell, the best way ( i kind of remember this, from along time ago) is to tie it in to the plumbing before it leaves the building,not having it be its own seperate entity.You really diddnt say witch bath, etc, because you have a 2 story home, go in detail on witch bath it is, upstairs or down, etc, if anything else is acting funny, etc. Later, jacob
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Normally you don't want soaps in a drywell.... Drywells are normally used for ground run off. Or are you talking about a septan tank..... then you do but you have to use an additive to clean out... a Septan tank is because there isn't a public sewer system in your area.... otherwise they are not allowed.... that's what I remember from IPC 2000.
