Shroud Fabrication for Dual Electric Fans w/Pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 502Burban, Dec 13, 2001.
  1. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I finally finished the write-up of my fan shroud fabrication. It's fabbed from aluminum sheet to fit two SPAL electric fans in a big-block radiator application. Lots of pics and descriptions of what I did. Here's the link: <a target="_blank" href=http://community.webshots.com/album/27011877IJsJEhiyEn>Fan Shroud Fabrication</a>.
    I'd like to give credit to BobK for the inspiration. His write-up is what gave me the idea. This is my first attempt to document something like this, so go easy on me.[​IMG] I tend to get into a project and forget to take pictures once I get into the "zone".[​IMG]
    As always, I welcome your comments and suggestions.[​IMG]
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>'73 GMC Suburban - 502DFI</a>
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    VERY NICE!!!! I have been wanting to do something like that with my electric fans! That is EXACTLY what I was looking for! Thanks and great detail on the write-up! Thanks!
    I'd like to check that out in person sometime as well as your cage, I'm right over the grade!
  3. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Nice job. It looks like you put a lot of work into it.
    How sure are you that it works? I noticed that you still don't have the whole thing back together.
    I'm thinking about taking my fan off to see what the noise/power benifits would be with electric fans. It's only in the 30's here so I don't think I'd have any problem with over heating on my short 8 mile trip to work. I'm really interested in switching to electric.
    Thanks for the photos.
    <font color=red>Spirit of 76</font color=red>
    <a target="_blank" href=http://homepage.mac.com/toddcripps/Menu2.html>homepage</a>
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Thanks for the write-up. Very nice job too. Let us know how well the set-up works with the big block...
  5. 502Burban
    Jun 8, 2001
    379
    Southern California
    Thanks! PM me and I can give you directions and we can figure out a time. Where are you? Camarillo, Oxnard...?
    Robb
  6. 502Burban
    Jun 8, 2001
    379
    Southern California
    Thanks! I'm just about positive that it will work. I've done similar setups on other vehicles. The challenge for me is always in the mounting details, and making it fit space-wise.
    These fans will be controlled by my fuel-injection computer, so will only run when the temp reaches 190*, then shut off at 180*. Should be pretty quiet, especially on the freeway, where I don't expect them to run much at speed.
    Robb
  7. 502Burban
    Jun 8, 2001
    379
    Southern California
    Thanks! I'll keep you all posted...[​IMG]
    Robb
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Hey Robb,thanks for the props .As my wife would say"Damn...that's a tight fit!"Looks like you had just enough room for the set-up to fit in.How thick was the aluminium sheet you used?Looks great,should work well too.Nice job!
    <font color=green>BobK<font color=green>
  9. 502Burban
    Jun 8, 2001
    379
    Southern California
    Thanks, Bob! I just used 1/4" thick for the aluminum sheet. I actually just went to a local welding/fabrication shop and they supplied, cut and bent the sheet to my specs. Only thing I would do different next time is to make the sides about 1/4" longer to make a tighter fit against the radiator tanks.
    Robb
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Looks good, I like the way you staggerd the fans- good thinking. Nice write-up too.
    <font color=blue>Twiz</font color=blue>
    Can't get it up?
    So, drop it in
    gear.
  11. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Looks sharp! I'll probably copy your design when I get ready to go to electric fans on my diesel.
    Keep us posted on the performance of your new cooling setup!
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  12. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    Sir, you do some very PRIMO work...............
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  13. 502Burban
    Jun 8, 2001
    379
    Southern California
    Twiz, Danno and Slayer,
    Thanks for the kind words about the shroud, especially the write up.[​IMG] That was something new for me.
    I'll let you know how the cooling system works out. Hopefully, I'll know B4 the end of the year. Ya never know...
    Robb
  14. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    That is some damn nice fab work to be proud of. BTW that big block looks sweet too.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  15. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    "BTW that big block looks sweet too"
    DAMN RIGHT!! The pics do NO justice!! I just went over and met Robb and checked out his Suburban. That thing is SWWEEEEETTTTTTTTTT!!!!!!!!!!!!!! EVERYTHING has been gone through. This thing is just awesome. The cage is BAD ASS. I cant say enough to describe this thing. You'd just have to see it in person[​IMG]. Robbs a real cool guy too! Talked with him for a couple hours!
    Oh and BTW, his idea for getting this beast in and out of the garage is GREAT!! Simple, and VERY effective its seems! Not sure if he has pics of his "custom wheels" or not[​IMG][​IMG]
