Shudder at takeoff,happy ending ( pages 1 2 3 4 5 6 7 8 9 )
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Espen88k5, Oct 19, 2001.
  1. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Here I have been walking around with a sharp claw in my stomac for over a month thinking tranny rebuild, converter failure, axle swapping and total bankrupt. And a new trannymount took it right away!! Also I used "metal-paste" to make the u-joint sit still in the slipyoke, that may have helped some to.
    I'l go do my happy-dance now. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    KEWL![​IMG]
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Did you replace the three missing flywheel bolts?
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  4. Espen88k5
    Feb 19, 2000
    981
    Norway
    I'v heard others saying there where only 3 bolts originally holding the flyweel and converter together on all the ones they had seen. It looks like there should be 6 though.
    Funny thing is the old mount looked fine untill I got it out.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are only 3 of the holes in the flexplate that get used. GM flexpates are drilled with dual bolt patterns, to fit multiple torque convertors without having to stock more parts. [​IMG]
  6. Rob 85K5
    1,487
    Pensacola, Florida
    On your earlier post it sounded more like the bolts for the flywheel to the crank? Is this not the case?
    Rob 85K5
  7. Espen88k5
    Feb 19, 2000
    981
    Norway
    I'm probably mixing the english words upp and being confusing. But the way Harry tells it is correct.
    I have to get me a Norwegian-English mechanic's translater.[​IMG][​IMG]
    Hey!! I can go drive it in city trafick again, now that I dont have to baby it into motion at every light [​IMG][​IMG]
  8. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Don't ya hate it when that happens[​IMG]?!? I've been through it twice with these stupid tranny mounts - I've gotten to where I keep a spare around. I've got a design drawn up for a replacement using polyurethane leaf spring bushings, much like Autofab's engine mounts pugsley.alloffroad.com
  9. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    was it the rear d-shaft u-joint that wouldnt sit still in the yoke? mine did the same thing, and i fixed it by putting c-clips on the caps. it made the u-joint fit perfectly and even.
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  10. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I replaced my pinion shaft yoke, it was eating u joints and finally people were telling me my driveshaft was wobbling
    $140. and a new pinion nut, didn't change the seal or crush sleeve, just set the preload on the pinion shaft.
  11. Espen88k5
    Feb 19, 2000
    981
    Norway
    It was the u-joint on the sliding yoke. The caps where wobbling in the yoke-ears. Originally I think they came with a epoxy-glue (at least my front u-joints had some, and I think I'm the first replacer of those.) Anyway, I could see the caps wobling a tiny bit but now they dont.
    My old trannymount could be stretched apart2 inches maybe, so that is where my shudder came from.powerfull 6.2 diesel trying to get 35" tires to start turning with 3.08 gearing. Put a lot of stress on the driveline, and the trannymount lifted enough for the rear driveshaft angles to start binding and shuddering.
  12. Espen88k5
    Feb 19, 2000
    981
    Norway
    I also decided to put the c-clips on there when I changed the u-joint at the rear axle.
    I couldn't figure it out any other way. The worn out one I replaced didn't have any though. Wonder how they got it centered?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They inject plastic in the yoke to hold it if it was a stock one. Usually when I remove those, they require a torch.
    Tim
