Shudder I can't find after adding 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by colorado_tahoe, Apr 6, 2000.
  1. colorado_tahoe
    colorado_tahoe Newbie
    Apr 6, 2000
    4
    Colorado
    Shudder I can\'t find after adding 4\" lift
    I've been trying to locate some bad shudders between 25 & 35 after putting a 4" suspension lift on the truck. No lift blocks, and did not turn the axle to compensate for the angle. Anybody have any suggestions or ideas what it may be??
    Colorado_Tahoe
    Ugly Truck, Pretty Wife
  2. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Re: Shudder I can\'t find after adding 4\" lift
    DRIVE SHAFT!! Might be the drive shaft. Mine did the same without a lift. My U-joints were screwed and it shudder BAD!! Check that and see. I could grab my drive shaft and shake it. HMMMMMMM don't think it's supposed to do that. HAHA Check it out. I'm sure you will get some more ideas from the other great guys. Good luck brutha
    "Crutch"
    "What me get stuck? NEVER!!"(Famous last words)
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    check your U joints.... they are now working at a new angle they may be almost worn to. Check the mounting of them also
  4. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    Same thing with mine after a 4" Superlift (all new springs). Like the others said - check the simple stuff first - make sure the balance weight is still on the driveshaft and check the u-joints for wear. If it's not that, the u-joint angles are probably off - the angles have to be pretty close to one another to cancel out each other's natural vibration/motion (or something like that). To remedy my situation, I lowered the transfer case a bit, but the u-joint angles are still about 3 degrees apart, so I'm going to replace the shims that came with the springs with larger ones.
    <font color=blue>Rob
    85 K5</font color=blue>
    [​IMG] 24 beers in a case, 24 hours in a day - Coincidence?
  5. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Your transfer case output shaft & the pinion yoke should be the same angle. If they aren't, this could cause your vibration. If you need to change your pinion angle, talk to your local 4x4 shop OR a local axle shop. They should have axle shims. Just get the correct one to fix it. If you need to drop you case (which I would NEVER do...) you can support the t-case with a floor jack, take the spacers out from under the crossmember for the t-case and put them between the chassis and crossmember. Another thing you could do it go to the local steel mill and puchase the steel and make a "drop kit". Just keep in mind, if you have a full time case (203) doing this will increase your front shaft angle, and just cause the same if not worse problem on the front shaft.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  6. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    I still don't get that t-case drop thing. I get the steps but I don't get the concept. I'm looking at it and doesn't it drop the tranny and engine? If so doesn't that put stress on the engine mounts? Someone said if you do it without a body lift you can come pretty close to the firewall with the distributer?
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  7. Corey-88K5
    720
    The drop kit for the T-case will tilt the motor, trans & t-case on the motor mounts. The motor mounts pivot and allow the t-case to drop lower. The main problem is the front shaft will be put a larger angle. This is usually a larger problem with 203's. And yes, it will place the dist. closer to the fire wall. You could replace the dist. with a C.F.I. (Crank Fired Ignition) But that would be expensive. Another option would be to move the motor further forward, and either remove the mechi. fan from the water pump and replace it with a electric fan.
    The main purpose of doing a t-case drop is you can tilt your pinion up on the rearend and it allows the driveshaft to run at a (total of) less angle.
    Best of luck, and if you need any other options, lemme know.
    Corey
    88K5
  8. bigjbear
    Feb 18, 2000
    13,973
    452
    Marietta GA
    If your driveshaft and u-joints check out ok and you have a part time case, drop the case about 1". All this is, is a set of spacers that go between the frame and crossmember. I have had no problem with the distributor cap hitting the firewall and I have an HEI ignition and that is about the biggest cap I know of. After I dropped my case all my driveline vibes cleared up. I have an NP205 case and a double u-joint on my front shaft, so a slight increase on the front output is not that big of a deal. If you need more info write back. Jim
    BigJBear '80 GMC
  9. _DeeVee8_
    _DeeVee8_ 1/2 ton status
    149
    Definetley check the drive shaft for movement(side to side)
    and look at the u-joiints-- they are almost always the culprits..
    4" lifts aren't that extensive to warrent adjusting angles of T-cases and engine to t-case angles.(unless otherwise noted)
    I ended up rebuilding all my u-joints to cure the chatters i had too.
    Rancho 4" lift
    -Dv8
    The only gun control this country needs is a steady hand.-- bumper stcker i saw once
  10. Steve88
    526
    Sunny Arizona !
    Corey, excellent description. That definately clears it up for me. Had no idea you could pivot a motor on it's mounts. I guess I should take a closer look under the hood.
    When I do my lift then I'm going to not plan on dropping the t-case (208) but know it's an option. I'd rather see how it goes and not do the drop unless absolutely unavoidable and as a low cost option to other, and probably better, choices.
    88K5 Silverado
