Sick 400??
Discussion in 'The Garage' started by GM Man, Sep 5, 2004.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Within the last week, when I go out to start up the Jimmy in the morning theres a real audible ticking sound coming out of the motor on the right side. Then as it warms up the ticking sound goes away. Now its starting to get worse, any ideas on what it is? Sticking lifter??? Thanks.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Possible sticky lifter, but more likely an out of adjustment rocker arm. Run the lash on the valvetrain, it will probably clear up the noise.
  3. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    I'd check your oil...just to make sure its not low/out!
  4. GM Man
    Jan 12, 2003
    549
    Denver CO
    Do you know if any major damage can occur if I drive it a little bit with an out of adjustment rocker arm?
    Thanks /forums/images/graemlins/thumb.gif
  5. GM Man
    Jan 12, 2003
    549
    Denver CO
    Just checked the oil and its full. /forums/images/graemlins/thumb.gif
  6. js4x4
    Jul 17, 2004
    798
    San Diego, CA
    having the rockers properly adjusted is pretty vital to prevent excessive/rapid wear...it just won't to breathe right, valves need to fully open and close.
